Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 42
Thread: Forum Slowness
  1. #31
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    Quote Originally Posted by Quattro
    ok, here is a trace route to mp3car. I know I did it at 1am, and I know you say the server are slow then, but I didn't have any other time to do the trace.
    Code:
    C:>tracert www.mp3car.com
    Tracing route to mp3car.com [154.6.109.11]
    over a maximum of 30 hops:
      1     2 ms     1 ms     1 ms  ool-44c20a90.dyn.optonline.net [xxx.xxx.xxx.xxx]
      2   277 ms   250 ms   329 ms  10.10.128.1
      3   200 ms   208 ms   186 ms  dstswr2-vl2.rh.hcvlny.cv.net [167.206.32.34]
      4   160 ms   171 ms   105 ms  r4-ge10-1.mhe.hcvlny.cv.net [167.206.32.13]
      5   283 ms   374 ms   243 ms  r1-srp9-0.wan.hcvlny.cv.net [65.19.104.209]
      6   161 ms   300 ms   252 ms  r2-srp1-0.in.nycmny83.cv.net [65.19.96.38]
      7     *        *        *     Request timed out.
      8   268 ms   173 ms   290 ms  p13-0.core01.phl01.atlas.cogentco.com [66.28.4.2]
      9   212 ms   109 ms   194 ms  p4-0.core01.dca01.atlas.cogentco.com [66.28.4.17]
     10   389 ms   297 ms   389 ms  p15-0.core02.dca01.atlas.cogentco.com [66.28.4.22]
     11   225 ms   194 ms   217 ms  p14-0.core01.atl01.atlas.cogentco.com [66.28.4.161]
     12   163 ms   158 ms    56 ms  tulix_systems.demarc.cogentco.com [38.112.7.86]
     13     *        *        *     Request timed out.
     14     *        *        *     Request timed out.
     15     *        *        *     Request timed out.
     16     *        *        *     Request timed out.
     17     *        *        *     Request timed out.
     18     *        *        *     Request timed out.
     19     *        *        *     Request timed out.
     20     *        *        *     Request timed out.
     21     *        *        *     Request timed out.
     22     *        *        *     Request timed out.
     23     *        *        *     Request timed out.
     24     *        *        *     Request timed out.
     25     *        *        *     Request timed out.
     26     *        *        *     Request timed out.
     27     *        *        *     Request timed out.
     28     *        *        *     Request timed out.
     29     *        *        *     Request timed out.
     30     *        *        *     Request timed out.
    Trace complete.
    I think the problem is with the backbones that you ISP uses, a few weeks ago Level3 terminated there pairing with cogent so it looks like your ISP uses cogent and the datacenter uses Level3 so its taking longer because it has to find a diferent route to get to the datacenter...
    But last i heard Level3 and cogent have restored there pairing, but im not 100% positve...
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
  2. #32
    Admin
    Aug 2005
    Please, people, please read these instructions before griping on the forums! Griping might make you feel better, but it won't help make the problems go away! While I do read the forums, I don't read them religiously, so please send your reports directly to me via email. (So far, I've received a grand total of exactly *one* trouble report.)
    I have been spending a lot of time on the forums during the past week, and so far I have not seen any problems that cannot be attributed to the problems described in my previously quoted message. As a result, I can only conclude that problems are network related, and that is why it is so important that I see a clean network connection to rule out network issues.
    Another networking issue I failed to address previously is that of DNS. If you get an error like BugByte got, try pinging the IP address (154.6.109.11) directly. If you can ping via IP address but not by name, then you have a problem with your ISPs DNS (this is a rather common problem.)
    Failing a real solution on the log thread issue, I do plan to institute a 1000 post limit on all threads. That is, any thread that reaches 500 posts will be closed for posting, and longer threads *may* be deleted from the archive entirely.
    -p.
    Quote Originally Posted by gnomad
    There are two known issues with forum speed at the present time:
    1. Various backup and administrative tasks are run between midnight and 4AM EST, and it is not uncommon to see slower performance during this time. I'm working with the server admin at the co-lo facility to see what we can do about lowering the priority of these tasks and to reschedule them to between 4AM and 7AM EST, when our logs show the least activity.
    2. Posts and accesses to long threads such as the infamous "My Thread" will often cause MySQL to go off and lose it's mind for 5-10 seconds, stalling all access to the forums. I'm working with the vBulletin authors to see if there is any way arround this other then capping the size of threads.
    I have received several reports of speed issues, and so far they have all fallen into one of these two categories. I welcome reports of problems, but they must contain the following information to be useful:
    1. The date and time (either in local of GMT/UTC format) of the problem
    2. A complete description of the problem.
    3. A ping log during the time of difficulty.
    4. Your IP address
    Here is a good way to create a log file:
    Open up a DOS command window, and type the following commands:
    ipconfig > log.txt
    date >> log.txt
    [control-c]
    time >> log.txt
    [control-c]
    ping -t www.mp3car.com >> log.txt <--- let this run during testing
    [control-c] <---- when done, press [control-c]
    date >> log.txt
    [control-c]
    time >> log.txt
    [control-c]
    Send all this information via email to [email protected], and I'll look into the problem.
    -p.
  3. #33
    Jan 2003
    Ruston, LA
    I have never had a problem with long threads.
    Maybe the issues with mysql "churning" are because some of the people
    here are using thread settings of 1000 posts per page.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  4. #34
    Unregistered User ODYSSEY's Avatar
    Feb 2001
    Raleigh, NC USA CarPC Ver3: [▓▒▒
    Quote Originally Posted by frodobaggins
    some of the people
    Took about as long as I expected, but didn't really lag.
    ODYSSEY
    Quote Originally Posted by Tidder View Post
    Digital-Car UK|
    (\__/)
    (")_(")
  5. #35
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    gnomad, I send you an email last week with all the information you requested, I'll send it again.
    Also I haven't had any problems with long threads on other vBulletin forums, either.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  6. #36
    Hosting Guru
    Oct 2001
    Atlanta, GA
    long threads isn't the problem, it's people using crazy thread views that is bad
  7. #37
    Hosting Guru
    Oct 2001
    Atlanta, GA
    and as far as network issues are concerned, level(3)'s network has been in the toilet for the last few weeks, jsut got off the phone with them again
  8. #38
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Tulip-Ryan
    Define crazy thread views? I used t ohave it set to 1000, but I changed it to 250. Loads up much nicer
  9. #39
    Hosting Guru
    Oct 2001
    Atlanta, GA
    you fir the definition
  10. #40
    Jul 2004
    Berkeley, CA
    What's your view?
  1. Topics from car forums.....
    By Spaghetti in forum Off Topic
    Last Post: 10-25-2004, 09:25 PM
  2. MUST READ: Forum Rules
    By Aaron Cake in forum General Hardware Discussion
    Last Post: 02-02-2002, 05:21 AM
  3. MUST READ: Forum Rules
    By Aaron Cake in forum Off Topic
    Last Post: 01-31-2002, 08:43 PM
  4. MUST READ: Forum Rules
    By Aaron Cake in forum General MP3Car Discussion
    Last Post: 01-30-2002, 11:00 AM
  5. MUST READ: Forum Rules
    By Aaron Cake in forum Classified Archive
    Last Post: 01-30-2002, 10:16 AM
