Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: New UserCP look.
  1. #11
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by RedGTiVR6 View Post
    I guess I'm missing what you're referring to when you say quick links.
    There are definately some repetitive redundancies being repeated twice here.
    The Quick Links
    The New CP Panel:
    1.9in x 2.9in -- 47mm x 73mm
  2. #12
    _
    Mar 2004
    Little Elm, Texas
    ok - I see where you're going. There are similar links in the two.
    However, this mod was an all in one. The UserCP links are more likely to be used here. Some folks are used to using the Quick Links, some aren't. This will catch those who aren't used to them.
    Jan Bennett
  3. #13
    Oct 2004
    NY
    the only difference to me is I used to use the user cp button as a refresh while in my user cp.... now instead of one click it's 2... if it helps lighten the load on the servers it's worth it though....
    not much of a big deal with redundant menu's & like you said, many may not have even realized the quick links... they can't miss this now though
  4. #14
    Mar 2006
    Quote Originally Posted by turbocad6 View Post
    Actually this I guess has been here for 2 days now, and I didn't even notice it until I saw this thread thisafternoon!
  5. #15
    Oct 2004
    NY
    one thing I noticed is before, a shortcut of :
    http://mp3car.com/vbulletin/usercp.php
    used to take you right to your control panel
    now the same shortcut takes you to the store? but this is still the correct url of your control panel..., but it just changes to mp3car.com & redirects...
  6. #16
    _
    Mar 2004
    Little Elm, Texas
    where do you find that link?
    the missing www seems to be the issue.
    Jan Bennett
  7. #17
    Oct 2004
    NY
    hey, your right... funny thing is, before it used to work, I got that link by dragging it from the address bar intially & that's the way it came up... thanks
