I've been doing my reading, and I'm going to play with HORM without EWF over the weekend. You still have to install EWF for HORM support but you can turn EWF off easily enough.
35's still goodtook me a long time to get to 12. Right now I'm working on an automated setup that includes all the tweaks I've made to get 12 seconds plus an auto-install of Winamp, Road Runner, Flash, directx, ffdshow codec, and registry tweaks. I can even have it go as far as installing EWF + HORM support automatically during setup. Right now I've just about got it done with Server2003 SP2. Will remove the Server specific tweaks and can then migrate the same setup files to XP. I'll have it at the next meet (as long as I can make it...June's looking tight for scheduling) for both XP and Server2003 flavors.
yep... EWF is sort of a p.i.t.a. sometimes, but overall I like it enabled better than disabled. Keeps my wife from fubaring things
I understand, ever time my wife gets in my truck I have computer issues. I think she has a anti-technology field or something. It seems like she has problems with anything computerized.
Do you have problems with iLists when you use HORM? I've had issues with them when I was using regular hibernation, which supposedly has to do with DirectX.
I haven't had any issues with ilists and HORM that I know of. What issues are you having with it? The only issue I have with HORM is the fact that Winamp doesn't really have a randomize feature so your playlist always restarts from the same point. I was going to try to find a way around that using a small USB thumb drive but haven't had the chance.
On a side note...I've been messing with an unattended carpc install and using Server2k3 SP2, I have it to the point where it will setup EWF for you, setup HORM, updated directx, flash9, 7zip, winamp 535, activewinamp, ffdshow codec, road runner, carwings and dfx3 skins, and bootvis (for optimising bootup time). Post install boot time with no further tweaks is 21 seconds in vmware. Will try and modify TinyXP this afternoon and hopefully get better results as the Server 2003 SP2 I used was a full copy (from work) and therefore the only tweaks were some simple registry tweaks.
There's a know issue with regular hibernation and iLists not working when you come back from hibernation. In my case any list that's an iList comes up blank until I reload the skin.
in that case...nope, don't have that problem with my HORM setup.
I'll have to give horm a shot then soon.
I've been playing with Micro2003 a bit this week. I'm having issues finding drivers that work with my hardware that don't get ****y about the drivers being XP only.
Can you guys explain HORM and EWF, still a newbie here!!!
The truck is still coming together. I've gotten several of my need-to-dos done, so I am getting closer and closer to driving her.
On other news, this is my traveling weekend for the month, so no garage time for me until Sunday evening...
I did have a pleasant surprise this afternoon when I arrived home... got my MOBO CPU RAM and a CF card to play with. I'm hoping to sit down and make a build of XP Pro for the card sometime soon and see how she runs. Still have to aquire my monitor (gotta order that this weekend) and a media HD drive, Best Buy is always close (that way wife doesnt know what I spent)
ewf = Enhanced Write Filter. What this basically does is write-protects your filesystem and uses a ram "overlay" to which changes are made. So anything that is normally written to the disk (ie, temp files and crap like that) are written to the RAM overlay. All changes to the system are then lost when the system shuts down. You can enable and disable EWF as you please to make changes to the system as well. Disabling can be done live. Enabling requires a reboot.
HORM = Hibernate Once Resume Many. Basically what is says. You have to install EWF to have HORM support (at least to my knowledge)..but you don't have to have EWF enabled for HORM to work. Basically what you do can do with HORM is load your system up, set things the way you want (example, I have RR loaded, as well as iGuidance, Winamp, Bluetooth software is connected to the device, etc) and then hibernate. All your data in RAM will be written to the hibernation file, however with HORM, even if you do a standard shutdown the system will resume from hibernation using the HORM setup.
btw - what CF card did you get? I've been looking on Ebay and have seen some nice 266x ones in the $50-75 range for a 4-8gb version.
btw # 2 - how does a 9 second boot sound? Just got it in a vmware build of XP
