Page 5 of 16 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 156
Thread: Infill G4 - Now Shipping
  1. #41
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Quote Originally Posted by mhk View Post
    I just pre-ordered the G4 for use in europe. Would it be better (if possible) to have streetdeck lite installed? I don't need the US maps. How much space on the hard disk would it save?
    Were currently only doing 1 image of the G4. It includes StreetDeck and North American maps. Deleting the map data is possible and would save around 1 gig.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
  2. #42
    Apr 2007
    USA
    Is there a general estimate of when this will ship? Not an exact day, but this week or in the next couple of weeks? I know you hate getting asked this... just anxious. Thanks.
  3. #43
    Jan 2004
    Quote Originally Posted by johnk View Post
    We are working on our 3rd release canidate image. It will probably get distributed to the testers tomorrow. It will take another day to verify the problems were fixed. Assuming no more major issues are found, it could ship as early as this Friday.
  4. #44
    Constant Bitrate DAE51D's Avatar
    Nov 2006
    Seattle, WA
    First of all, I'm super excited and want to get this and take advantage of the $500 discount (when does that expire?)
    512MB is barely enough for XP and other programs. Is there another SODIMM empty slot? Or is there a 1GB upgrade? I would hate to just have to throw away the 512MB SODIMM that comes with it just to upgrade to more RAM.
    What size is the HD (2.5" or 3.5")? I'm assuming it's a notebook drive?
    Is it possible to get it without the HD? I want to put in a much bigger 160GB notebook drive (or even bigger if it's a 3.5" drive). I have almost 250GB of MP3s, that's not even counting the movies/videos I want to put on it.
    Not a real big deal as long as I can swap out the stock drive with my own drive.
    Can I get it without the ~$100 WindowsXP boxed version? I have an MSDN subscription and volume license -- don't need to buy another one.
    I'm assuming the 802.11b/g is a USB dongle? Does it happen to have an external antenna jack on it?
    What is the BlueTooth/Microphone you offer?
    I have a USB bluetooth dongle already -- will that work?
    Is the microphone noise cancelling and something that is mounted in the visor or something? Or is it a BT headset mic?
    What is that Kyocera KR1 Mobile Router (box with antenna looking thing) shown in the picture?
    https://store.mp3car.com/PhotoGaller...Code=SDK%2D014
    Is there a way to (quickly) dim the contrast/brightness of the display, so when I'm driving at night, this thing isn't God's own flashlight shining on me and glaring out the corner of my eye.
    How does "power-down/hibernate" work? When I turn off the key on my car, what happens? I assume this has an intelligent shut-down sequence. Personally I'd like it to Hibernate.
    I have a 2007 Scion tC -- I want to put it in that center console area, do you know if the Scion door will fold down over the G4? Do I need any sort of mounting kit for this -- I have the factory stereo in there now.
    http://daevid.com/gfx/tC/1600/DCP_3217.1600.jpg
    Will the reverse camera work with my Scion tC?
    How do I find out (before I buy the camera)?
    The specs say "Brown - Remocom - This is for steering wheel control"
    [a] will this work with my Scion tC?
    [b] what is actually controlled via the steering wheel?
    Mine has Volume Up/Down, Mode, and another Up/Down button.
    What about Linux drivers and such for this? Things like the display/video-card, USB, audio, etc? I would like to give some of the other Linux CarPC GUI's a try too. At least, can you provide more detail as to what chipsets they all are so I can look them up?
  5. #45
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by DAE51D View Post
    Considering Windows has been optimized to run on this hadware, and considering what you will be doing with StreetDeck, it's more than enough. I have not noticed anything running slow on the G4 I have here.
    Notebook.
    No, you cannot get it without the HDD. If you pull it apart to replace the HDD, you will void your warranty. You will also have to re-register your copy of StreetDeck, since the G4 is shipped as a unit that needs no configuration or install.
    No. Again, we have spent a lot of time and effort streamlining windows and applying licenses for many of the features that make the G4 what it is.
    I don't believe so.
    No - this has been discussed in detail elsewhere on these forums.
    In order to use StreetDeck bluetooth features, you must use the MP3Car.com bluetooth dongle. The feature is only guaranteed to work with this dongle.
    Since bluetooth stacks are not standard, we had to lock down the hardware to ensure the functionality.
    Yes, it is noise canceling. Again, this has been detailed elsewhere in this forum. It is a wired mic.
    As an upgrade. If you want to be able to use your EVDO card, you will want the KR1 router or the like.
    There is an illumination wire in the harness out back. You would wire it up to the illumination lead behind your dash.
    It's just like any other power supply for a CarPC right now. It's intellegent. The PC will go into stand-by for 72 hours then will do a hard shut down. If it senses low voltage (not sure about the exact number) it will also auto shutdown.
    We have no way of knowing about every vehicle on the market.
    Why wouldn't it? You buy the camera seperately, it's the same camera that's on the store.
    Use these forums. That's what they are here for.
    You will need an adapter for this to function correctly. You cannot just hook up the wire and expect it to work.
    We do not support linux and there are no known drivers for it.
    Jan Bennett
  6. #46
    Elsewhere
    Someone answer me this...
    The whole concept behind the Infill models (G4 & T3) is to have a consolidated all-in-one vehicle PC thgat's easy to install for the PC novice.
    AS such, it delivers on that, and in spades.
    Why bother tweaking it? If you want a system that you can tweak or build to your personal specifications, then just @#($*&#@$(*@!!!! build one! You'll save a lot of money in the process.
    Big deal if you have a G4 w/ 1GB of RAM and a 16GB HDD. You still have an Infill G4.
    Even if you run some other frontend on the unit, it's still a G4.
    It's like taking a shiny new HP (or other brand) PC from Best Buy or whatever, then immediately upgrading the RAM and HDD on it. You still have the same base PC, only with more RAM & HDD. Whoop-dee-freaking-dee.
    I guess I see it this way:
    If you want to tweak and tinker and modify your setup, then build one so you can do that. If you want a clean all-in-one unit that's painless to install, then get an Infill model.
    Sorry, but voiding the warranty on a $2000 piece of hardware just to add some gigabytes of storage space doesn't make any sense to me whatsoever.
    How about the Wiki?
  7. #47
    Feb 2005
    Quote Originally Posted by DarquePervert View Post
    find me a case/enclosure in that form factor and I will gladly buy it!
    One of the reasons we have carputers is the fact that we can have more storage than a fn IPOD!
    another reason for building or buying carputers is BEEN ABLE TO TWEAK THEM!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  8. #48
    _
    Mar 2004
    Little Elm, Texas
    The G4 has been designed as a solution for the mass consumer market. As such, it might not meet the needs of the usual hobbiest.
    Jan Bennett
  9. #49
    Elsewhere
    Quote Originally Posted by spiro View Post
    Maybe that's you. I never embarked on my project because I wanted to have something better than an iPod. I wanted more functionality than I could afford to buy gadgets for. Ultimately, I wanted a PC in my ride. Not an iPod. Not a TomTom. Not a bluetooth cellphone device. Not a headunit with USB or MP3 CD capability.
    See, I look at buying a computer for your car and building a computer for your car as two very different processes. Buying one is for people who don't want to **** with it at all. That's who the G4 is for. Frankly, it's too damned expensive to start disassembling and modifying it.
    It's far cheaper to build one from parts you collect yourself and tweaking it to your heart's content.
    $2200 Infill G4 = NO TWEAKING
    $400 pile of PC parts = Tweak Central
    As Red stated. The G4 isn't aimed at the hobbyist. Frankly, swapping a HDD or a RAM module in a tiny formfactor pre-assembled in-dash unit doesn't make for much of a hobby to me.
    now, if I were to lay hands on a demo unit or something for free or very low cost, I would certainly crack one open to see what I can do to modify the thing. That's how I am.
    But as a tinkerer, I'm not going to purchase one just to have something to tinker with. I've got a half-dozen other PCs here that I can tinker with.
    How about the Wiki?
  10. #50
    FLAC Nola111's Avatar
    Jan 2007
    New Orleans, LA
    The G4 is available from other places in barebones form. Knock yourself out dude.
  1. INFILL G4 - Australian and New Zealand Questions Answered
    By INFILLG4 in forum General MP3Car Discussion
    Last Post: 04-30-2008, 12:21 AM
  2. Infill G4 StreetDeck install
    By michelk in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 04-23-2007, 01:47 PM
  3. Infill G4
    By TheMaskedMan in forum General MP3Car Discussion
    Last Post: 02-18-2007, 08:43 AM
  4. Replies: 78
    Last Post: 09-08-2005, 07:29 PM
