Results 1 to 10 of 15
Thread: Changing LEDs and Updating HDD
    Variable Bitrate Deric's Avatar
    Sep 2006
    Does anyone know how difficult it would be to change out the red LEDs to Blue? I'm swapping out all of my green LEDs in my car to match the blue of the MyColor instrument cluster and would prefer not to have red in there as well. Also is updating the HDD that difficult? I haven't seen any inside pics of the unit.
    Thanks,
    -Deric
    _
    Mar 2004
    Little Elm, Texas
    Regarding LEDs - the unit is so new that I doubt that anyone has taken it apart yet to change out the LEDs. Doing so will void your warranty.
    Regarding the HDD - again, the unit is so new that I doubt that anyone has taken it apart yet to change out the HDD. Doing so will void your warranty.
    Jan Bennett
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Updating the HDD is more time consuming then difficult, but there are some ribbon cables that are somewhat sensitive to tearing. If you've completely taken apart a laptop before, the G4 should be similar.
    The LEDs are square and have 4 contact points each and are 4 mm wide. I haven't tried replacing them. They are on a seperate circuit board also containing the buttons and IR sensor. Don't take this as an endorsment or a recognition of this as covered under the warranty in any way, but they look no more difficult to replace then the circuit board mounted LEDs in my car and would say it is possible to successfully do, but still can't confirm it. If you do attempt this, I would be very careful when soldering around the IR sensor as it is probably sensitive to heat.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Apr 2007
    NE ITALY (near Venice)
    hi, here you can see how to replace the dvd reader and the hd.
    this document is from www.cartft.com
    http://www.cartft.com/support/doku/m...ill_G4_ENG.pdf
    Mar 2007
    Quote Originally Posted by giannidsg View Post
    Nice! Looks pretty simple I was afraid that the guts of the G4 would be a mess but the layout seems pretty clean. Much better then the innards of the MacBooks and Ibooks I'm used to seeing.
    -beef
    Apr 2007
    Moscow, Russia
    Quote Originally Posted by god_of_cpu View Post
    ...which makes me wonder why would a simple LED have 4 contact points? Is there any chance of them being multi-color LEDs? If so, there must be some easy way of powering different contacts to get different colors?
    Jan 2004
    Quote Originally Posted by Marassa View Post
    They are not multicolor leds.
    Mar 2007
    Quote Originally Posted by beefHeart View Post
    -beef
    Looks far more easier than upgrading the T3 harddisk and memory. I'd say the T3 is a 8 out of 10 on the difficulty scale..
    The T4 is a 6 for HDD and 7 for memory at that
    Low Bitrate emperorjj1's Avatar
    Jun 2007
    Las Cruces NM
    that doesnt seem too hard even for a noob like me... but im still sota concerned. Will doing this void warrenty of the unit? Is it possible to get the unit "empty" or with any HDD or dvd drive of my choice?
    _
    Mar 2004
    Little Elm, Texas
    I'd wait to see the store once we recieve the next batch.
    You will not be able to select the CD drive for sure, however, we're looking into HDD and memory options.
    Jan Bennett
