I do not have a red volume icon in the system tray.
I did find one in the control panel though. I also did use it to set the audio to 6 channel.
The sub out line is STILL dead.
Will updating the sound drivers harm anything?
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
As long as you use the correct drivers, reinstalling them shouldn't harm anything.
Besides changing the output to 6 channel and updating the drivers later tonight, what else can I do?
i had same problem.
had to enable 6 chan sound.
then i just muted the center channel
I finally figured it out last night. Turns out for some reason when you switch to 6 channel audio, it does not make the change until you reboot. So you have to switch to 6 channel, then reboot the G4. After that all was well.
You shouldn't have to reboot. It should work as soon as you change the setting... There was probably something else amiss.
I rebooted several times with it set to 4 channel, but never with it set to 6 channel.
Well all I care about now is that it's fixed.
