Results 1 to 8 of 8
Thread: Power specs of the G4?
    Low Bitrate drakino's Avatar
    Apr 2007
    Austin
    Just got the G4, and it's going to be a little bit before I can get it installed in the car. I would like to start playing with it though before I install it, so that I can work out the sound card, and some other things ahead of time. It runs on 12v, but how many amps does it need when it isn't driving speakers? The inline fuse seems to be 15a, and the unit has a 13a marking on the bottom. I'm going to grab a DC power supply for it here shortly, but don't want to go overboard with a 15 amp monster for just the G4 if it's not needed.
    Aug 2004
    California
    I dont know anything about amps, but its a computer. I ran mine fine on the bench using a cheap/standard 380W computer power supply. I just tapped into the 12v line for power and ACC, the ground the ground wire (naturally) and jumped pins 15 and 16 on the ATX connector to power it on.
    Apr 2007
    Austin
    I grabbed one of these from Frys and it seems to be working fine:
    http://shop3.outpost.com/product/1992595
    Apr 2007
    NE ITALY (near Venice)
    I have tested the g4 take 3.2A when work
    May 2007
    sacramento
    Raysind
    i want to get a g4 but i need more hard disk space can install a larger drive like 160 gig
    Apr 2007
    in my infill I have an HD of 120Gb, I think you can install a HD as large you need, but you must use the 2.5", I don't know if there is HD largest than 120Gb for HD of 2.5" (see www.cartft.com)
    Newbie nissancar's Avatar
    Oct 2003
    Low Bitrate marci's Avatar
    Jul 2007
    Switzerland
    for testing enviroment you should use a power supply with 12V and 5A. (normaly used the G4 without peak 3A)
    Some 2,5" HDD´s are critical, you should look to the temperature specifications and shock specifications..
    As sample, in a car like mine we have sometimes -20 degrees and i have not light shock absorbers in my car. (bumpers) is a heavy duty 4x4 car-.. ;-)
    see picture, current when he do nothing...
  1. FAQ: How do I power my DC-DC PSU on my workbench?
    By DarquePervert in forum The FAQ Emporium
    Last Post: 12-14-2011, 07:55 PM
  2. Power Supply/OPUS Kill Switch
    By SpaceMonkey in forum Power Supplies
    Last Post: 08-11-2006, 11:58 AM
  3. Travla AC/DC power supply cable
    By Change in forum Power Supplies
    Last Post: 07-25-2006, 11:04 PM
  4. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  5. Install coming up... but Power questions
    By technopsych in forum Power Supplies
    Last Post: 04-14-2004, 08:16 PM
