Results 1 to 10 of 11
Thread: mappoint
    mhk
    mhk is offline
    Mar 2007
    amsterdam
    mappoint
    I purchased the G4 from mp3car with SD. Should I go ahead and purchase microsoft mappoint europe? Is it true that mappoint is the best way to go with streetdeck? Does anyone know if there is a trial version of mappoint? I don't want to spend hundreds of $ for something that doesn't work.
    Thanks for your response
    _
    Mar 2004
    Little Elm, Texas
    Map Point is the only navigation software that is supported within StreetDeck.
    The G4 will not include maps for Europe. If you want Map data for Europe you will need to purchase Map Point for Europe and utilize it.
    Jan Bennett
    mhk
    mhk is offline
    Mar 2007
    amsterdam
    Thanks,
    So this would not work at all on the G4? http://www.microsoft.com/uk/homepc/a...s.aspx?pid=001
    I guess it would work on the G4 in windows but not in SD? Would that be a problem? Using autoroute in windows on the G4?
    _
    Mar 2004
    Little Elm, Texas
    you would have to run it as an external program from StreetDeck.
    Jan Bennett
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Quote Originally Posted by mhk View Post
    Thanks,
    I don't think autoroute is compatible with the GPS in the G4, I haven't tried it though, you can always add an external USB GPS to it.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Variable Bitrate JasonMK's Avatar
    Jun 2007
    Annapolis, MD
    Microsoft Streets and Trips is basically the same as Mappoint, right? So would i be able to the buy the annual update and install it or will I run into problems?
    _
    Mar 2004
    Little Elm, Texas
    StreetDeck uses MapPoint.
    S&T will not run properly within StreetDeck.
    Jan Bennett
    Jun 2007
    Annapolis, MD
    Thanks for the 411
    Apr 2007
    NE ITALY (near Venice)
    mappoint language
    hi, I have buyed one licence of SD and mapoint europe, when I use GPS navigator it speacks in english, how to change language? I think there is a text file in SD or Mappoint with the indication ( Ex. Turn left, Turn right etc.) and the TTS read this file, can we change this file and write the indication in italian?
    thanks
    _
    Mar 2004
    Little Elm, Texas
    If you've purchased the lite version, then the voices are from MP Europe, not StreetDeck.
    In your other post where you asked how to do this in StreetDeck, Chuck informed you that the file was not writeable.
    I would contact Map Point to figure out how to change their program.
    Jan Bennett
  1. Replies: 33
    Last Post: 05-30-2007, 10:54 PM
  2. mappoint wont install on network
    By chewEboy in forum GPS
    Last Post: 01-24-2006, 06:39 PM
  3. BMv2 Mappoint 800 * 480 .Skin Files
    By IntellaWorks in forum RR Skins
    Last Post: 11-14-2005, 04:03 PM
  4. GPS and MapPoint 2004 questions.
    By wampa in forum MediaCar
    Last Post: 07-15-2004, 06:40 PM
  5. Replies: 13
    Last Post: 07-15-2004, 01:07 AM
