Results 1 to 6 of 6
Thread: G4 in a Bmw e46
    Aug 2006
    G4 in a Bmw e46
    Does anyone know if the G4 can fit into a bmw e46 using the double din bezel, also i dont know how much room there might for it to slot in.
    Thanks Kev
    Elsewhere
    As long as the height & width are standard double DIN (7" wide X 4" high), the only consideration would be depth....
    How about the Wiki?
    Aug 2006
    Quote Originally Posted by DarquePervert View Post
    Thats just what i was thinking, ive seen photos of people that have installed the pioneer avic double din unit, i suppose the G4 cant be far from the size of that.
    Kev
    _
    Mar 2004
    Little Elm, Texas
    I do not know much about BMWs.
    If your BMW is newer, you will need to check if you can hook it up to the factory amplification without any adapters or if you will need any adapters for your vehicle.
    I would recomend picking up a dash kit and a wiring harness for your particular vehicle to make installation easier.
    Jan Bennett
    May 2007
    Atlanta
    you will need to do some serious vent modification..... www.e46fanatics.com and search for double din install (there are about a billion of them, sift through and find the ones with pics.) This is the reason I went with a PC in the trunk.... much easier.
    Maximum Bitrate srcstc's Avatar
    Dec 2003
    New Jersey
    Yes it'll fit. You can use my double-din bezel.
    http://www.mybimmer.net/doubledintrim.htm
    $50 dollars to the first person that sends me pics of one installed using my bezel.
    Rich
  1. Project BMW E46
    By zaid175 in forum Newbie
    Last Post: 03-09-2007, 10:04 AM
  2. Replies: 3
    Last Post: 02-06-2007, 06:40 PM
  3. Replies: 2
    Last Post: 10-26-2006, 01:16 AM
  4. FS: Complete bmw e46 carputer system
    By RiXst3r in forum Classified Archive
    Last Post: 07-19-2005, 09:28 PM
  5. Mac Mini powered ICE in BMW e46 with Steering Wheel Controls support
    By Piperclub in forum Show off your project
    Last Post: 06-15-2005, 04:50 AM
