Results 1 to 7 of 7
Thread: G4 and screen flicker?
    Jun 2007
    Well, after such a long time, I've finally gotten around to actually installing the G4 in the truck. I had to do a lot of dash trimming to make it fit, but it goes in now without problem.
    My issue now is that it flickers when plugged into the factory harness. No issues on the test bench--even removed it and brought it back in to make sure I didn't stress the wiring too much and short something. No problems at all. Annoying flicker when plugged in.
    I searched around for some troubleshooting tips, but I didn't see anything posted that seemed to solve anyone's problems. Any ideas on how to best start isolating this problem?
    Thx,
    Rip
    Apr 2007
    San Dimas, Cali
    Unhook the illumination wire and see if it solves the problem. The illumination wire can't have varying voltage, just on or off. I am pretty sure that will fix your problem. You can use a relay instead of directly connecting to the factory illumination wire to fix it.
    Variable Bitrate JasonMK's Avatar
    Jun 2007
    Annapolis, MD
    The wiring kit for my 2007 Saturn VUE (GMOS-LAN-06) has both an illumination (orange wire) and a dimmer (orange/white). Which one should I connect if I want to avoid this flicker issue myself. I haven't installed it yet, just mapping out what all the wires need to be connected to.
    Jun 2007
    IandI, you're onto something there.
    I figured out a few things. Just an FYI in case anyone else has this problem.
    As long as it's set for daytime, there's no flicker problem. When it adjusts for night, it flickers when there's any dimming at all. If I adjust the interior dash lights to full (which I never drive with on full), then the flicker stops.
    However, if I adjust the screen brightness settings so that ultimately there's no real switching of the G4 from daylight to night modes, of course, there's no flicker.
    Hope that helps someone out there...
    Rip
    Sep 2006
    Sydney
    had the same problem.
    Just wired a relay in place so when lights are on the G4 has a full power source.
    is back. FKA Robert Wray
    Fiberoptic's Avatar
    Jul 1978
    Baltimore, MD
    Blog Entries
    143
    Now what would be very cools is have the backlight of the g4 dimmable based on that varying g4 voltage. Somehow I doubt this is a standard voltage range, but none the less this could be an interesting idea to incorporate.
    Jun 2007
    Quote Originally Posted by Fiberoptic View Post
    That would be sweet. Even on the darkest setting, the G4 is still a bit bright for me at night.
    I may have to try the relay thing... No matter what I do, the Nav maps flash with the illumination wire connected.
    --Rip
  1. G4 review
    By johnk in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 12-12-2007, 12:25 PM
  2. FS: cracked screen iBook G4 -
    By mccdeuce in forum Classified Archive
    Last Post: 07-08-2006, 03:48 PM
