Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: What are ALL of the wires on the G4 harness?
  1. #11
    Mod - all of it. SapporoGuy's Avatar
    Aug 2009
    SonyLand
    I came across the same thing. Just plugged it in
    However, Darque could be right.
  2. #12
    Raw Wave
    Nov 2009
    Quote Originally Posted by JasonMK View Post
    It seems odd then that the yellow is so thick with the red wire (acc) so thin on the harness.
    Never question the wisdom of auto manufacturers - it's like alternator "S" (sense) wire that are thicker than the others (charge lamp, ignition +12V) yet the S circuit draws way under a charge lamp circuit (eg, 10uA - 10mA).
    It is possible that the constant (yellow) draws high power - especially when the unit is turned on - but in that case the wire's fuse will blow if the circuit is overtaxed, hence no harm in trying....
  3. #13
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Thanks.
    I would assume that the yellow wire is the main power wire, and red is only used as an ignition sense, much like an amplifier perhaps?
    RevFE
    My Shop
  4. #14
    Variable Bitrate JasonMK's Avatar
    Jun 2007
    Annapolis, MD
    Quote Originally Posted by OldSpark View Post
    I'm not quite sure if you meant this seriously or toungue-in-cheek [Washington's bailout of the auto industry]. It is the auto manufacturer that has the skinny yellow wire, and the carputer's wiring harness that has the thick yellow. Never doubt the computer manufacturer? Regardless it seems as if my safest bet is to run some thicker guage wire directly to the battery, as DarquePervert and the FAQ suggest. It would just be that much simplier to patch it to the Ford Wiring harness (as I had done with my Saturn), now I need to find a way through the firewall and under the hood.
    _______________________________________________
    All installed, and ready for visitors. Infill G4 in a 2007 Saturn VUE
  1. Need help with a Ford Taurus 2002 stock stereo
    By markis00 in forum Car Audio
    Last Post: 06-02-2009, 11:28 AM
  2. *panic* Extending LCD wiring... harness?
    By LycaonX in forum LCD/Display
    Last Post: 06-12-2007, 09:27 PM
  3. G4 F.A.Q. - Please read here before posting your questions!
    By RedGTiVR6 in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 04-23-2007, 08:16 AM
  4. Bad to use power/gnd wires on OEM harness?
    By aec merlin in forum Car Audio
    Last Post: 07-05-2006, 05:39 AM
