Results 1 to 10 of 14
Thread: What are ALL of the wires on the G4 harness?
    Variable Bitrate JasonMK's Avatar
    Jun 2007
    Annapolis, MD
    It was easy enough to figure out what MOST of the wires are, but there are still a few shown that are not described. So far the manual and this site list the following:
    Green/Black - Rear Left Negative
    Green - Rear Left Positive
    White - Front Left Positive
    White/Black - Front Left Negative
    Purple/Black - Rear Right Negative
    Purple - Rear Right Positive
    Gray - Front Right Positive
    Gray/Black - Front Right Negative
    Light Green - Reverse Gear
    Orange/White - Illumination
    Pink - Attenuator
    Brown - Remocom - This is for steering wheel control
    Blue - Antenna Turn On
    Light Blue - Hand Brake
    Blue/White - Amplifier Turn On
    Red - Accessory
    But where is the ground? Also what is the thick yellow wire in this picture?
    My GMOS-LAN-06 harness is looking for a yellow 12v constant coming out of the G4, but I didn't want to assume that just because there is a yellow wire it is what I was looking for. Attached is the .pdf for the harness is that is helpful.
    Jun 2007
    Hi JasonMK,
    The thick yellow wire is the +12V constant power. The red is the +12V ignition hot wire. The black wire is the ground.
    Hope that helps.
    Rip
    Jun 2007
    Annapolis, MD
    Thanks Rip, that's what I assumed...but you know what they say about when you assume. Odd that they left that out of the latest draft of the manual.
    _
    Mar 2004
    Little Elm, Texas
    Next time you find a problem with the Manual - please post it in the thread where I've posted the manual and asked for feed back.
    It's easy to skip over those wires because they are the same for EVERY head unit on the market and is considered a standard.
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    Manual has been updated.
    Jan Bennett
    Jun 2007
    Annapolis, MD
    Quote Originally Posted by RedGTiVR6 View Post
    Thanks so much, I hadn't thought of that.
    I did assume it was something that everyone else new, but me. Glad I asked and even more glad to get an answer. Thanks for the help and amazingly quick response. I'm glad I bought my G4 from a company this on the ball, just can't wait for it to arrive!
    Jun 2007
    Annapolis, MD
    I know this is an old thread, and I am not too optomistic that anyone will respond...but just in case. What do I do if the [Ford] factory "yellow" wire is much thinner than the thick yellow one on teh G4 harness? Th emanual says
    Yellow – Power. This wire must be
    connected to the battery in the car.
    Do NOT splice this wire into a wire of
    a smaller gauge. Doing so will risk
    the unit not operating properly and
    could cause an electrical fire. If the
    wire in the factory harness is the
    EXACT same gauge as the wire on
    the G4 harness, splicing into it will
    suffice.
    Do I just buy some thicker wire and connect it straight to my battery?
    _______________________________________________
    All installed, and ready for visitors. Infill G4 in a 2007 Saturn VUE
    Elsewhere
    Quote Originally Posted by JasonMK View Post
    That would be your best option, IMHO.
    How about the Wiki?
    Raw Wave
    Nov 2009
    Although the yellow (constant) should not be taking much current - it is only for memory, clocks etc.
    Jun 2007
    Annapolis, MD
    Quote Originally Posted by DarquePervert View Post
    Thanks.
    Quote Originally Posted by OldSpark View Post
    It seems odd then that the yellow is so thick with the red wire (acc) so thin on the harness.
  1. Need help with a Ford Taurus 2002 stock stereo
    By markis00 in forum Car Audio
    Last Post: 06-02-2009, 12:28 PM
  2. *panic* Extending LCD wiring... harness?
    By LycaonX in forum LCD/Display
    Last Post: 06-12-2007, 10:27 PM
  3. G4 F.A.Q. - Please read here before posting your questions!
    By RedGTiVR6 in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 04-23-2007, 09:16 AM
  4. Bad to use power/gnd wires on OEM harness?
    By aec merlin in forum Car Audio
    Last Post: 07-05-2006, 06:39 AM
