Results 1 to 8 of 8
Thread: Add on HW recommendations for G4?
    Low Bitrate marci's Avatar
    Jul 2007
    Switzerland
    Hi @ all,
    have anybody Hardware recommendations for the Infill G4?
    I need a LAN Card 10/100Mbit (USB?) and a Bluetooth Stick with newest Bluetooth Standard.
    as second i want a small active microphone for the G4 (3,5mm stereo jack?), maybe with noice canceling technology for free speaking.
    that all to order in germany ;-)
    I want to use the centrafuse software with the g4 hardware, the feel & look is more serious than other software.
    anyone idea?
    Elsewhere
    Why a LAN adapter? You're going to have a LAN in your car?
    Frankly, using Centrafuse witht he G4 will be a waste, as most of the built-in hardware is not supported... At least not as of yet.
    How about the Wiki?
    Jul 2007
    Switzerland
    yes, i have a redudant wlan/umts router in my car, and one additional server jetway j7f4k with two lans and some other things that require a normal lan connection.. and: i need a USB LAN Card, thats need no special driver like NE2000 Network cards, for imaging the system over LAN.
    (My infill has no CDROM, i restore all of my Servers over LAN Boot) (perhaps that not working over USB LAN Card, but i can boot from USB Stick)
    Jul 2007
    Switzerland
    maybe, i need a second VGA output again, i need dual monitoring with VGA 800*600 quality. i have too displays, one for technical data of heading, and the other for control details.... does anybody know, how i can install a second vga output?
    i think at a USB Port replicator from Fujitsu-Siemens for it ultra small notebooks (maybe it is a targus device) with vga output, is not fast, but it is working for small (not highspeed) applications..
    where you see in the picture the becker Radio,
    there i will mounted the G4 later. the 8" TFT upperside
    should be the second display...
    Jul 2007
    Switzerland
    for all they are interested an a second touchscreen: Targus sell a USB docking station called
    ACP50
    see
    http://www.compusa.com/products/prod...ct_code=318362
    Mobile Docking Station with video output
    - 4x USB Type A
    - 1x RS232 serial
    - 1x Ethernet 10/100 Base-T Network
    - 1x Mikrophon IN
    - 1x Audio OUT
    - 1x USB Type B
    - 1x 15 D-sub pin VGA (max. Auflösung 1280x1024, 16 bit)
    i evaluate this port replicator 2 years back for a big company, perhaps that will work..
    (i must organize that first, and test, what 2 Touchsceens do together ;-)
    maybe is a great idea, to enhance the missing outputs of the G4..
    Elsewhere
    I don't know for certain, but I'm willing to bet that a USB port replicator like that Targus unit will jack around with Hibernation and Standby, whicht he G4 uses.
    How about the Wiki?
    Jul 2007
    Switzerland
    yes, we will see ;-) tomorrow i will get the USB Port Replicator, then i will test it, with my other 8" TFT Touchscreen ;-) i hope that it works, so i can mount the G4 at the bottom and leave my 8" TFT upstairs in the middle of my car. perhaps, only the mounting in a KIA Sorento at the bottom is tricky. normally the radio is on the top where there is now mounted my 8" TFT. In Europe i don´t found the mounting kit to mount the 2DIn Radio at the bottom but i see that in the other KIA Sorentos outside from Europe ....
    puhh we will see it will be getting a hard time, to solve all the problems ;-)
    P.S. nice modifications and clean installation of your hardware :-) well look :-)
    at the following picture is it like i want. You see the radio (where i want to have the G4 mounted) at the bottom (mounted in a 2 DIN case)
    But where do i get this 2 DIN plastic mounting kit (bracket) to mount the radio at the bottom?
    at the moment it looks like that: (with a 1DIN Becker radio)
    Jul 2007
    Switzerland
    Today i get the ACP50, and the first tests sounds well.. :-)
    here in the german CarPC Soap you can see first some pictures ;-)
    http://www.car-pc.info/phpBB2/viewto...=189958#189958
    later, when all works i will tell you my experiences ;-) (sorry for my bad english)
  1. Add More Roads to a destinator Map?
    By bns2000 in forum Map Monkey
    Last Post: 01-21-2008, 12:03 PM
  2. How do I add more commands?
    By boostedGT-S in forum PV FAQs
    Last Post: 11-03-2006, 11:45 PM
  3. Recommendations for a good deep cycle battery?
    By Vchat20 in forum General Hardware Discussion
    Last Post: 09-10-2005, 06:03 AM
  4. Replies: 7
    Last Post: 02-26-2005, 01:46 PM
  5. how do I add a sub?
    By TiTUS in forum General Hardware Discussion
    Last Post: 10-01-2003, 08:53 AM
