If you get the mp3Car Bluetooth adapter I would rest easy knowing they verified the drivers against the cpu before shipping. As for the work around, that depends on if the drivers are actually hard coded for Intel CPU's (which I find hard to believe), or if the install is just crappy (which is pretty likely). You could try installing the drivers on an intel machine, then grabbing the files and copying them over. Worse case you get a system crash, boot to safe mode and remove the drivers.
LinkBack URL
About LinkBacks
