Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: G4 and Shock - Crashes A Lot
  1. #21
    Apr 2007
    San Dimas, Cali
    Quote Originally Posted by Marassa View Post
    Tried it - seems like it does not hang on "system on" hourglass any more - it just crashes immediately (unless I wait for some time before restarting it)
    While exploring BIOS I found "System Thermal" setting somewhere under APM and it was Disabled on my system. I wonder if it has something to do with the thermometer icon mentioned above. Is System Thermal Enabled on your G4?
    OK, well that's a start to fixing your problem. I think you problem is that your power supply is not adequate for the G4 since you said you are bench testing it. I had similar issues when I was bench testing mine. I had mine hooked to one of those battery jumpers. It worked fine for a couple hours, but when the battery ran down the G4 acted very erratic. It rebooted, crashed and other sorts of weird things and also depended what I had plugged into the USB ports.
    I have been reading about the bios settings and, yes, you can set the system thermal to lower your CPU rate when the CPU reaches a certain temperature. The CPU probably does this on its own without that setting enabled, but if you wanted to set it to a lower level you could. This would help for people that think their system is crashing due to temperature of the CPU. I am trying to make a digitalmod to display the temp, fan speed, and CPU rate for the G4 so we can monitor this. I think Speedfan will do it also out of SD.
    Can someone with a G4 out of the dash and turned on try to slap it on the side and see if it locks up or reboots? I am still trying to isolate my shock problem and this info would help me.
  2. #22
    Variable Bitrate JasonMK's Avatar
    Jun 2007
    Annapolis, MD
    Quote Originally Posted by IandI View Post
    Must say this made me chuckle the first time I read it, mine is all safe and sound inside my dash. But the thought of giving me $2k G4 a whack did make me laugh. I'm sure it wouldn't hurt it, but can't help here. Sorry.
    On a side note, within 30 minutes of opening my G4 package I was already installing mine and I haven't had any hardware related problem (the AM issue is apparently a SD update, should be fixed or I'll just go back to the last patch). Hope you two get it all figured out.
    _______________________________________________
    All installed, and ready for visitors. Infill G4 in a 2007 Saturn VUE
  3. #23
    Apr 2007
    Moscow, Russia
    Yes, definitely, and I appreciate your info about BIOS.
    No, I am not bench testing it any more, it's been sitting in my car now for two months now.
    Thanks for the info on system thermal settings. Will investigate further.
  4. #24
    Apr 2007
    Moscow, Russia
    Just an update: my G4 was recognized as defective by the local dealer and replaced with a new one.
  5. #25
    Apr 2007
    live? Baltimore. From? NY
    I made a movie of my shock problem. I wonder if the mp3car staff will take a look to see if this is caused by the hard drive
    Where is the video located? I would love to see this. I man handle my G4 (mine was free) and I have no issues with shock.
    Also look into doing a thorough hard drive scan. I can't recall a program name off hand but the tools on ultimate boot CD work great.
  6. #26
    is back. FKA Robert Wray
    Fiberoptic's Avatar
    Jul 1978
    Baltimore, MD
    Blog Entries
    143
    I would also love to see the video. The disk checker in windows is here:
    Right click on C drive
    Click Properties
    Click tools.
    Chick Check now.
    Check boxes as applicable
    Click start.
