Results 1 to 8 of 8
Thread: Infill G4 Size Specs
    Sep 2006
    Looking arround through the forums and the manual I can not seem to find the size specs on the Infil G4 I understand the Outer Dimension is Double Din Size but what I need is a dimensioned drawing of the face plate area. I inted to purchase one of theese but am unsure if it will interfere with the bezel that is currently arround my stereo.
    I plan to install it in a 2002 Monte Carlo SS which has a curved bezel arround the stock stereo picture below. (stock Monte LS picture from some dealers website)
    Anyone think there will be an issue?
    Apr 2007
    Moscow, Russia
    I'd say if there exists a double din kit for your car then G4 should fit. It's as simple as that.
    Sep 2006
    I know it will fit in the hole but Im worried that the bezel might interfere with the buttons or the screen tilting so i was looking for some dimensions.
    Apr 2007
    Moscow, Russia
    Quote Originally Posted by xufer View Post
    Ok, I will try to measure mine, but I'm afraid I will not be able to do that until Saturday. But I can give you some clues right now:
    Vertically, you will need complete 2DIN height if you want to have G4 flush with your bezel: the G4 faceplate is slightly less tall but it needs extra 2-3 mm to open.
    Horizontally, you can get away with about 2 mm less than 2DIN on each side.
    Sorry, I don't do inches
    _
    Mar 2004
    Little Elm, Texas
    You can place the G4 on a flat surface and the face plate will fold down without hitting anything.
    Hope that helps.
    Jan Bennett
    Sep 2006
    metrics are no problem heh, when ever you get a chance to measure it, it would be helpful. Im going to take my dash apart this weekend to get a handle on what i have for space back there. My only goal is to have this thing installed by the middle of october so i have some time.
    Im off to try and hunt down a wiring diagram for my car as I need to see how the factory amp is wired up.
    Variable Bitrate JasonMK's Avatar
    Jun 2007
    Annapolis, MD
    If it helps at all, I've got tons of pics of my install complete with pics of me measuring it. Follow the link in my signature if you'd like.
    _______________________________________________
    All installed, and ready for visitors. Infill G4 in a 2007 Saturn VUE
    Low Bitrate marci's Avatar
    Jul 2007
    Switzerland
    please let see us some pictures of your installation into your car :-)
  1. CF 1.2 on Infill G4
    By SUNAJ in forum Centrafuse
    Last Post: 08-21-2007, 07:38 AM
  2. Replies: 7
    Last Post: 08-13-2007, 07:15 PM
  3. Mach 1 with Infill G4
    By flapster in forum Show off your project
    Last Post: 08-08-2007, 01:47 PM
  4. G4 F.A.Q. - Please read here before posting your questions!
    By RedGTiVR6 in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 04-23-2007, 09:16 AM
