Results 1 to 10 of 12
Thread: Raise antenna thru software (w/o radio)?
    Jun 2007
    San Jose California
    I need to find a way to raise the power antenna, preferably thru software. It works fine when I select the radio in streetdeck, but exiting the radio/streetdeck puts it back down. Is there a software/utility I can use to manually raise (and lower) the antenna thru windows (outside streetdeck)?
    _
    Mar 2004
    Little Elm, Texas
    thread moved since this isn't G4 specific. You're more likely to get responses in here.
    Jan Bennett
    Jun 2007
    San Jose California
    This is g4 specific, what are you talking about? It's the wire coming out of the g4 I want to control. Streetdeck can control this, so it's obviously possible thru software, but I dont know if the g4 came with a way to do this, or if I need to download something, or what.
    _
    Mar 2004
    Little Elm, Texas
    what you are wanting to do is not specifc to the G4. if there is software avaliable out there, it will work on any powered antenna, not just the G4....there's nothing super special or propritary about the antenna output on the G4.
    The people that might know of that kind of software would be more likely to browse htis forum than the G4 forum...
    Jan Bennett
    Apr 2007
    Moscow, Russia
    Quote Originally Posted by enigma9o7 View Post
    Of course this is G4 specific. Read this thread.
    _mxn_OpenRadio@0 function raises the antenna (among other things).
    Apr 2007
    Moscow, Russia
    Quote Originally Posted by RedGTiVR6 View Post
    Thanks, it's only 9AM but you already made my day
    Low Bitrate marci's Avatar
    Jul 2007
    Switzerland
    uhh interesting... maybe when you know wich bit enable the 12V signal. Than i tink can program a little VB file. easyier is it, to make a little switch. automatic antenne cable needs only +12V to turn out. if you disconnect the +12V the antenna is turning in..
    not the best way, but practicable. i have the same problem, i will use later an external TMC/RDS recceiver for the navigation, and they need the Antenna ;-)
    well luck :-) let us know how you fixed that problem ;-)
    BG
    Marci
    Jun 2007
    San Jose California
    Normal computers don't have a wire/connector coming out of them that is used to raise/lower a power antenna like the g4 does. To me that's special or propritary. Unless the g4 uses some standard interface for carpcs or something, if so let me know the details and I'll try to find info from whoever makes that interface or whatever...
    Quote Originally Posted by Marassa View Post
    Well based on that thread, I'm guessing it's not as easy as I hoped - I was thinking maybe there was already a program made that would do it (maybe even already on there), not that I'd have to learn how to write one! Only basic programming I've ever done was on an apple 2, did a little c++ under unix while I was in school, but certainly don't know anything about Windows programming or dlls or visual-anything.
    Jul 2007
    Switzerland
    welcome :-) Those were the days. i remember back to Apple II+ with CP/M Card :-) Thatīs was the time where we young and where hackers be still hackers :-) hehe, no internet, only slow connection via acustik coppler and 300baud :-))))
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    Sure this is G4 specific. The antenna output is not specific, once OUT OF the G4.
    There is no such thing as a software to control antennas, it's a silly 12v line switched, what pc has such an output, dedicated to car antennas?
    If you add some simple hardware (usb -> serial + relais), it's very simple to make a little program that does what you want. Would be much prettier if it used the proprietary power antenna output of the G4 though.
    Chuck should know this...
    Or maybe a workaround: make a plugin for streetdeck that leaves the radio playing in the background but switches off the sound from it?
    Good luck!
    Joachim
  1. Can A Wireless Network Adapters Antenna Be used for GPS or Radio?
    By Lava in forum General Hardware Discussion
    Last Post: 06-13-2006, 06:32 PM
  2. XM Satellite Radio to Unveil XM Advanced Services at 2006 Consumer
    By Will Albers in forum General MP3Car Discussion
    Last Post: 03-27-2006, 09:49 PM
  3. control radio antenna power to go up via usb
    By dim-8 in forum General Hardware Discussion
    Last Post: 08-04-2004, 11:32 AM
  4. Need urgent help to buy radio e antenna
    By Denun in forum General Hardware Discussion
    Last Post: 07-23-2004, 03:39 PM
  5. Using radio antenna for radio AND tv
    By pyros in forum General Hardware Discussion
    Last Post: 05-19-2004, 02:06 AM
