Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: What After formating my ingfill g4
  1. #11
    Newbie ojindia's Avatar
    May 2007
    Syria
    Quote Originally Posted by RedGTiVR6 View Post
    I feel it should be mentioned again that if you plan on using StreetDeck and having the Aribic language on your PC you will probably run into problems.
    I try that and see the problems.
    I need arabic just in Windows. to see files named in arabic.
  2. #12
    May 2007
    Syria
    Quote Originally Posted by ABTsportsline View Post
    If you want it just for the underlying windows install, are you not using StreetDeck while in your car? What are your main uses for the G4 if you're not running StreetDeck?
    I cann't work with G4 without SD, but this not mean that I'll did not work with windows.
    If I get Restore DVD, how to install Arabic language on the system???
  3. #13
    Variable Bitrate JasonMK's Avatar
    Jun 2007
    Annapolis, MD
    Quote Originally Posted by ojindia View Post
    I'm not 100% positive, but I am pretty sure that the restore DVD is a disk image and therefore you won't be given a language option. Equally not 100% positive, but can you use your Windows disk and do a "repair" install and swicth the language? Never tried it, just a thought. But, again, as has been mentioned, expect to run into "issues" if you deviate from the supported install options of mp3car.com
    _______________________________________________
    All installed, and ready for visitors. Infill G4 in a 2007 Saturn VUE
  4. #14
    Apr 2007
    Moscow, Russia
    I wonder what kind soul told you that you need to reformat your drive to get that. All you needed to do was go to Windows Control Panel/Language and Regional Standards/Languages and tick "Install right-to-left languages support" (sorry for rough translation from Russian but it should be close). This way you would have retained StreetDeck in working condition and got the possibility of working with Arabic language in Windows apps (but NOT in StreetDeck!).
    Now I presume you have installed Arabic version of Windows, right? Well, StreetDeck will not run on it correctly unless you do some deep hacking.
  5. #15
    May 2007
    Syria
    Quote Originally Posted by Marassa View Post
    Thanks for your help!!!
    I added arabic lang. by your way. I'll wait Restore DVD to install it and end this situation.
    Thanks againe.
  6. #16
    Jun 2007
    Annapolis, MD
    I'm glad it looks as if it will work out for you in the end, let us know how it goes after you get the restore DVD.
  7. #17
    May 2007
    Syria
    Quote Originally Posted by JasonMK View Post
    I Will!
  8. #18
    Low Bitrate ABTsportsline's Avatar
    Oct 2005
    Seattle
    this is what i was referring to earlier. don't know who recommended the formatting either, poor guy
  1. G4 and Shock - Crashes A Lot
    By IandI in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 08-10-2007, 11:40 AM
  2. please help info needed G4
    By showmr2 in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 08-03-2007, 03:04 PM
  3. please help info needed G4
    Last Post: 08-03-2007, 11:26 AM
  4. G4 F.A.Q. - Please read here before posting your questions!
    By RedGTiVR6 in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 04-23-2007, 09:16 AM
