Results 1 to 10 of 18
Thread: What After formating my ingfill g4
    Newbie ojindia's Avatar
    May 2007
    Syria
    I decided to format my G4.
    1- Firstlly I Copied folder in C:\OEM_Drivers.
    2- Format HardDisk And Install windows
    3- Install all drivers in copied folder OEM_Drivers
    4- Download StreetDeck from Internet And Installed it.
    The problem is:
    - one of the drivers doesn't work
    - StreetDeck doesn't work
    - Radio, Music, Vedio, Navigation And other things doesn't work in StreetDeck
    - Can't Registration StreetDeck.
    Any one can help me.
    Low Bitrate ABTsportsline's Avatar
    Oct 2005
    Seattle
    why did you decide to format? were you having problems?
    Variable Bitrate JasonMK's Avatar
    Jun 2007
    Annapolis, MD
    Quote Originally Posted by ABTsportsline View Post
    I believe that might be a mute question at this point (I wondered it myself, but we all have our reasons)
    OJINDIA, Do you have the full version of SD? The navigation is actually Microsoft MapPoint, which may need to be installed separately. Some of the features do not work properly if SD is unregistered.
    IF you bought your G4 from MP3car.com then you should call and request a restore disk. I believe it is actually a disk image that should restore it to "like new" condition, complete with working drivers and the latest release of SD.
    _______________________________________________
    All installed, and ready for visitors. Infill G4 in a 2007 Saturn VUE
    May 2007
    Syria
    - I formated to install arabic lang.
    - What's SD.
    - I haven't any Restore DVD or CD.
    - I bought G4 From Mp3car.com, How to order restore disk.
    Apr 2007
    Moscow, Russia
    Quote Originally Posted by ojindia View Post
    Is it really necessary to reformat the disk to install a language?
    By the way, you should know that StreetDeck does not support any language using non-Latin letters and it will not work correctly on a non-English version of Windows.
    - What's SD.
    StreetDeck
    You should order it.
    Try the same way you ordered your G4 from them.
    Good luck!
    May 2007
    Syria
    Marassa
    Thanks for your answers.
    I need arabic lang. just for windows files.
    It was a folder OEM_Drivers, All Drivers in it, That's What I Think.
    After format and install all driver And Download SD from Internet. GPS, Radio, SD doesn't work.
    How I can download Restore DVD from internet (I'm in Syria).
    Elsewhere
    Marassa
    Unless you purchased your G4 from the mp3car.com store (here), you're not entitled to the restore DVD.
    It appears that you purchased it from another vendor, which means that you should contact them for support.
    If the unit came with Windoze pre-installed, then they are legally required to provide you with a copy of Windows to reinstall, if needed. The restore DVD in question is provided with the G4 units sold through the mp3car.com store.
    How about the Wiki?
    _
    Mar 2004
    Little Elm, Texas
    I feel it should be mentioned again that if you plan on using StreetDeck and having the Aribic language on your PC you will probably run into problems.
    Quote Originally Posted by Marassa
    Jan Bennett
    Oct 2005
    Seattle
    i know it is after-the-fact at this point, but you can install the Arabic language pack while running windows normally - no need to reformat. If you tried this and it didn't work, nevermind. if you did not know about this, PM me and i'll give you the details.
    but again as others have said, if you are running StreetDeck as your front end, it won't support that language pack. If you want it just for the underlying windows install, are you not using StreetDeck while in your car? What are your main uses for the G4 if you're not running StreetDeck?
    May 2007
    Syria
    Quote Originally Posted by DarquePervert View Post
    I bought G4 from MP3car.com by my friend in US and he sent it to me.
    I received G4 Without any Restore CD. Just WinXP Home Edition And WiFi Driver CD.
  1. G4 and Shock - Crashes A Lot
    By IandI in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 08-10-2007, 11:40 AM
  2. please help info needed G4
    By showmr2 in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 08-03-2007, 03:04 PM
  3. please help info needed G4
    Last Post: 08-03-2007, 11:26 AM
  4. G4 F.A.Q. - Please read here before posting your questions!
    By RedGTiVR6 in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 04-23-2007, 09:16 AM
