Results 1 to 3 of 3
Thread: G4 volume buttons
    Aug 2007
    G4 volume buttons
    Hello,
    I've got a problem with my G4 volume control (both in Infill station and Centrafuse).
    When I increase the volume with the G4 volume button, it's working great. But when I push the volume down button, the system goes into MUTE state imediatly.
    If I use the remote control, or the volume button on Centrafuse, the work fine. The problem is only with the volume down button of the G4
    Any Ideas?
    P.S - The mute button works fine.
    Low Bitrate marci's Avatar
    Jul 2007
    Switzerland
    yes, i think it´s a hardware problem.
    when you disassemble the g4 unit and have a look to the buttons, you see, the key technics is like a old remote control from a television. (Folie) i think you have a problem with "one of the buttons is always pushed" (not really mechanical stable - the construction)
    sometimes you have the same thinks like this, when a button always pressed e.g. press the vol_up button and the vol_down or the Mute in same task.
    send it back, if you have warranty. and dont use that buttons often. better you use the touchscreen buttons or the remote control.
    please let me know, if you fixed that problem.
    maybe it can helps, when you open your g4 front panel, and place (fix) the circuit with the button electronic to the right place ;-)
    Jul 2007
    Switzerland
    see that:
    G4 'Mute' Button Not Working...
    perhaps that the same problem ? the "beep" is internal controlled, the internal elecronic switch is multi layered switched ?
    Maybe, but as i see that buttons as i put out my new g4 from the box, i don´t trust them :-)
    (hehe, i was same years in the mobilephone evaluation :-)
  1. G4 F.A.Q. - Please read here before posting your questions!
    By RedGTiVR6 in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 04-23-2007, 09:16 AM
  2. Road Runner Volume Issues ! ! !
    By rewindnottm in forum Road Runner
    Last Post: 03-20-2007, 04:38 AM
  3. Auto volume on startup
    By stric in forum CF Plugins
    Last Post: 03-05-2007, 05:43 PM
  4. Can I redirect volume buttons?
    By IntegraKarim in forum FP FrodoComm
    Last Post: 03-03-2006, 01:21 AM
  5. Volume does not work on main screen
    By drewinstl in forum CF Bug Reports
    Last Post: 07-11-2005, 06:53 PM
