Results 1 to 4 of 4
Thread: Will The Infill G4 Fit My 2006 Lincoln Town Car?
    Jan 2008
    Talking Will The Infill G4 Fit My 2006 Lincoln Town Car?
    Hello mp3car comunity, I'm joselmar a new member of the comunity, I was wondering if the G4 unit willfit my 2006 lincoln town car, because I'm deep interest on install one of these, and also if these are capable to handle differents softwares to play music like the bpm, raduga or pcdj, etc..
    I'll be very thanksfull with all the information that I can get.
    thanks
    _
    Mar 2004
    Little Elm, Texas
    If your vehicle has a double din opening, then it will most likely take the G4.
    As for the software, it runs StreetDeck if you purchase it from Mp3Car.com. I would suggest doing a bit of research about StreetDeck as I'm sure you will have other questions about the software.
    Jan Bennett
    Jan 2008
    OK....what about amplified system integrations? happens that I have an high amp output sound system but integrated with the factory system, using a Level Output Conveter (Audiocontrol LC7) to convert the high signals in to 4.5v to manage my 3 amplifiers.
    can I just use it with the G4 or so I have to think in some other options?
    Oct 2007
    Yes you can use a high to low signal converter. I am using one on my system for my front speakers, the rear speakers on my setup goes directly to the G4.
  1. Radio module Infill G4 and SILAB
    By SUNAJ in forum Centrafuse
    Last Post: 12-18-2007, 05:14 PM
  2. Replies: 9
    Last Post: 06-08-2006, 06:15 PM
  3. OBD for LINCOLN TOWN CAR
    By DK888 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-02-2005, 03:52 AM
  4. 95 Lincoln Town Car (Install Pending)
    By Noble in forum Show off your project
    Last Post: 04-01-2004, 11:57 PM
