Results 1 to 5 of 5
Thread: Infill G4 completely off when switching ignition off
    Mar 2008
    Hi,
    I've got a strange problem with my Infill G4.
    Whenever I park the car and turn the ignition off, it immediately kills all power to the G4 which results in the G4 to be turned off right away.
    When starting the car, the bios and windows are loaded again.
    How is this possible? I thought the G4 has a smart power supply which nicely "sleeps" your G4 when you switch off the ignition?
    Apr 2007
    USA
    Check your Settings to make sure it is set to go to Standby when you turn the power off. I forget which Setting category it's under though.
    Dec 2007
    Sydney Australia
    Check you don't have the battery and ignition cables connected in reverse.
    Variable Bitrate JasonMK's Avatar
    Jun 2007
    Annapolis, MD
    Quote Originally Posted by deniax View Post
    Hi,
    Any update? Have you figured it out or are you still having teh same issue?
    _______________________________________________
    All installed, and ready for visitors. Infill G4 in a 2007 Saturn VUE
    Mar 2008
    Yes, the garage that build in the Infill had indeed connected the battery and ignition cables in reverse like RedheadKev wrote.
    Everything is working now
  1. CF on an Infill G4 & Navigation
    By dally28 in forum Centrafuse
    Last Post: 03-12-2008, 10:29 PM
  2. Infill G4 stopped working
    By haiminger in forum Centrafuse
    Last Post: 11-11-2007, 03:54 PM
  3. ODB-II for the infill G4 and Hummer H3
    By haiminger in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 09-28-2007, 03:08 PM
  4. Replies: 7
    Last Post: 08-13-2007, 07:15 PM
  5. Req DVD functions from Infill G4 in CF
    By SUNAJ in forum Centrafuse
    Last Post: 07-26-2007, 12:49 PM
