Results 1 to 4 of 4
Thread: Infill G4 build - Audio Problem
    Jul 2008
    Unhappy Infill G4 build - Audio Problem
    First off let me make it clear I did not buy this unit at the mp3car store so it was not pre-setup. I purchased a barebones kit and am in the process of installing it in my truck. I've now reached the point of having the OS installed, multiple frontends installed for testing and wiring and fitments done for the dashboard. What I didn't check, and am now very confused about, is the audio output. I installed it in the truck and got nothing. It's wired to a factory standard 4 speaker setup. I removed it and went back to the testing bench. If I hook up a pair of headphones to either the center-channel or sub outputs (the RCA ones) I can hear the music (though quite soft) but only if playing thru Centrafuse not Windows media or Winamp. The Left, Right, Front, Rear all have no sound (I've hooked them to tiny 30W home theater speakers). I've installed the latest HD audio Realtec driver, set the speaker setup to 6 and exhausted any other ideas. I am sorry for what seems to be a newbie question but I am truly at wits end...
    Sep 2008
    I am also Newbie and have the same problem!
    Though I can get sound from RCA both from Centrafuse and Windows.
    I thought it could be the amplifier that was disfunctional and had a friend to look at it inside, but there was nothing to see and the IC chip on the amplifier looked fine. He haven't tried to measure the power through the components, but that is the next step.
    I will try to reinstall XP and all the drivers again, before taking the next step.
    Do somebody have another suggestion?
    Variable Bitrate JasonMK's Avatar
    Jun 2007
    Annapolis, MD
    Do either of you have the infill drivers for the audio? I know StreetDeck and Infill worked out something for the two to play nice together. I only ask not knowing what software/drivers comes with a "barebones" kit.
    _______________________________________________
    All installed, and ready for visitors. Infill G4 in a 2007 Saturn VUE
    Sep 2008
    Quote Originally Posted by JasonMK View Post
    I've got the audio drivers with the barebone. It's a cd from Maxan. And I have also tried the drivers at cartft.com for Infill G4. But nothing changed.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. G4 with Infill Station
    By flapster in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 01-10-2008, 08:27 AM
  3. CF 1.2 on Infill G4
    By SUNAJ in forum Centrafuse
    Last Post: 08-21-2007, 07:38 AM
  4. How to Power an Infill G4 Unit using an ATX PSU
    By snakeye5 in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 06-20-2007, 07:52 PM
  5. Hard audio quality problem: Noise / Ground loop?
    By Burat in forum General Hardware Discussion
    Last Post: 09-09-2004, 07:08 AM
