I did open it and used the batter trick..... it reset the BIOS.... all the USB's now is working... the only problem is that the SSD is not working i tried to install windows 7 but it i reach the hard disk formatting stage and i setup the hard disk and when i get to the window where it will begin the setup it will give 8x0 error and it will say that it can't unpack the files...???!!
LinkBack URL
About LinkBacks
the system. no USB device is detected at all.
is easier way to either reset the BIOS to default or a way to login to the bios with out a keyboard. i know opening the device and taking the battery off and return it should do the trick but is there a faster or easier way other than that
