Estimated Release Date: April 16th, 2007
Features:
CPU: C7 1.5GHz
Memory: 512MB DDR2 (SODIMM)
LCD: 800 X 480 6.5″ Touch Screen
Audio: HD Audio CODEC
USB: Front 1 port / Rear 2 port
HDD: 40GB HDD
DVD-ROM: DVD Combo
RADIO: FM section:87.5~108 MHz / AM section:153~1710 KHz
AMP: 44W x 4CH max (22w x 4ch nominal)
GPS: GPS Module
The connections on the back of the G4 are as follows:
Here's a listing of the various wires out of harness:
- 2 USB plugs
- Mono Center RCA output (blue)* - 2.5v output measured
- Mono Sub RCA output (orange)* - 2.5v output measured
- Rear Camera Input (yellow)
- TV Out (yellow) - NTFS
- GPS Antenna Port
- DMB Antenna (Non-Functional - DMB hardware is not included in the US version)
- Microphone
- Radio (Motorolla Female)
What's in the package:
- Green/Black - Rear Left Negative
- Green - Rear Left Positive
- White - Front Left Positive
- White/Black - Front Left Negative
- Purple/Black - Rear Right Negative
- Purple - Rear Right Positive
- Gray - Front Right Positive
- Gray/Black - Front Right Negative
- Light Green - Reverse Gear
- Orange/White - Illumination
- Pink - Attenuator
- Brown - Remocom - This is for steering wheel control
- Blue - Antenna Turn On
- Light Blue - Hand Brake
- Blue/White - Amplifier Turn On
- Red - Accessory
Additional Parts (NOT Included) You May Need for the Install:
- Remote
- Magnetic GPS antenna and interior mounting plate
- Mounting Screws
- Stylus
- A/V breakout cable
- USB Extention Cable
- Harness to connect the unit to your speakers and for all other connections
Other Notes:
- Car Specific Double DIN Kit / Face Plate
- Car Specific Wire Harness
- Car Antenna Converter
Features supported in StreetDeck:
- The rearview camera input is completely implemented in hardware. It is activated when it detects you are in reverse through the use of reverse gear detection wire and switches the display from the computer to the rearview camera. The computer does not have to be booted for this to work.
- The screen has 7 different tilt angles. The angle is remembered when starting up and the screen completely closes when it is turned off. To tilt the screen, just press and hold anywhere in StreetDeck where there is not a button. If the top of the screen is pressed, the top tilts in, if the bottom is pressed, the bottom tilts in.
*Please note: If hookinig up to an amplifier and not using the built in one, this unit only has 2 RCA outs. 1 for a mono-sub channel and 1 for a mono center channel. The suggested solution is to pick up a USB sound card. I will be listing some options for this shortly.
- BlueTooth (yes, BT!)
- AM/FM Radio
- GPS
- DVD playback
- CD playback
- OBD-II scanning
- Internet Radio
- Navigation
- You can set the color of the user interface to match your car.
- Video Play Back
Jan Bennett
