Page 24 of 28 FirstFirst ... 141516171819202122232425262728 LastLast
Results 231 to 240 of 271
Thread: Infill G4 thoughts and comments
  1. #231
    Elsewhere
    Except for one problem.....
    The streetdeck software is tied to the physical hard drive, so imaging hte drive with Ghost (or anything comparable) would require you to re-register your streetdeck, and possibly render it useless.
    How about the Wiki?
  2. #232
    Oct 2004
    NY
    another good reason to have you guys do it
    the default image can be 40 gig's, a larger drive could keep that same 40 gig partition with the remainder as a media partition...
    as far as this unit not being latest greatest PC power wise, it's similar to buying an ultra portable, in that your trading off raw power for convenience, I could see offering the base config at 40 gigs, & then just 1 or 2 optional upgrades, these upgrades could be at a premium that would make it worth your while, & at the same time alleviate a lot of apprehensions about buying this unit for many...
  3. #233
    Newbie TurboTronix's Avatar
    Apr 2005
    Canada
    I think the price is way too high, these specs can be obtained at the fraction of the cost if you build it by yourself (you can even get better specs if you shop around).
    Also, most people on here I believe are into the DIY and at the lowest price possible so this is not a good alternative when it comes to that department...
    Don't be a pilot between drivers, just a faster driver in a plane!!
  4. #234
    _
    Mar 2004
    Little Elm, Texas
    Then the G4 is not targeted towards you.
    This is not a product targeted towards the DIY market.
    It is a product targeted towards those individuals who do not have the time and patience to research, part together, install, and trouble shoot a CarPC.
    The tooling required for such a product is not cheap. This mobo is NOT an off the shelf MOBO. There are propritary products in the G4 as well that require a good deal of research and development...that costs money.
    Have you taken any business classes? Have you taken any manufacturing classes? Marketing? Anything?
    All of these classes will teach you about the cost of products.
    People seem to think that it's all black and white. That the WalMart and the NewEgg of today is how everything is done. It's such a shame really.
    Jan Bennett
  5. #235
    Apr 2005
    Canada
    No need to downgrade people to prove a point...
    I did not say this product costs less to manufacture, I was implying that you could get something similar for a better price if you go the DIY way.
    In any case, I actually thought it was a very nice device that offers plenty to whom ever could afford it.
    I believe I am entitled to my opinion
  6. #236
    _
    Mar 2004
    Little Elm, Texas
    You are absolutely entitled to your oponion.
    Your comments seemed to me, unnecessary if all you were trying to do was restate the obvious. Because of that, I felt that that's not all you were trying to do, and responded as such.
    Jan Bennett
  7. #237
    Apr 2007
    USA
    Angry
    Looks like there is a serious showstopper problem with the suggestion of using an external USB hard drive to overcome the 40GB storage limitation:
    This will not work through the unpowered USB hub (at least with my new Western Digital 80GB Passport drive). It must be connected directly to one of the 3 USB ports.
    That might not be an impossible problem, except for the fact that the external USB soundcard I got (Turtle Beach "Audio Advantage Roadie") also fails to work with the USB hub.
    That leaves me with either my music files and no audio, or audio but not my music files. (Or of course I could have my USB HD dangling out of the front USB port, but nobody could seriously make that suggestion.)
    Needless to say, after all these months of waiting I am extremely disappointed. I will be stuck with the 40GB limitation and only have a portion of my FLAC-based audio library, largely defeating the whole point of my purchase. Not sure what to do now...
    Also I guess I must just be really dumb (since this should be an easy thing to do), but I see no way to play music from my external drive (or even from any other directories on the internal hard drive). It only has an option for the DVD drive.
  8. #238
    Feb 2005
    Quote Originally Posted by johnk View Post
    The rear USB PORTS power my 120GB IBM HDD without xternal power!
    I think you should scroll down some more it should be there, mine is.
  9. #239
    Apr 2007
    USA
    Quote Originally Posted by spiro View Post
    Right, that's what I meant - the standalone USB ports work fine. But since there are only 2 rear USB ports, I have to choose between either my hard drive or my sound card (since one of the rear USB ports is already taken by the hub that is used for WiFi and Bluetooth).
  10. #240
    Apr 2007
    USA
    Screw it... I'm just gonna buy a reasonably-sized notebook HD and go through the hassle of swapping it out (and I guess having to buy a new SD license?).
  1. Thoughts & Comments on this PSU
    By badass101 in forum Power Supplies
    Last Post: 07-28-2004, 06:21 AM
