Results 21 to 30 of 32
Thread: Bluetooth Car unlocker
  1. #21
    Apr 2010
    Quote Originally Posted by soundman98 View Post
    i believe that justchat's point was that the send-a-picture-from-your-phone-to-a-wireless-printer-to-trigger-a-remote-to-open-the-doors is a lot like a rube goldberg device-- ie: a highly complicated way of doing very simple tasks--the specific image he posted deals with getting toohpaste onto the toothbrush...
    i solve the problem with by using a coat hanger, calling someone with a spare set of keys, or calling the police.. none of these are usually as fast, but they are much cheaper..
    Today after school I had a dentist appointment so I was kind in a hurry. I went into my trunk to get my phone and wallet and as the deck lid was closing i noticed my keys in the corner... I called AAA and they were able to unlock my car but it to 45-50 min. but I missed my appointment and had to reschedule it for wed. I would have been really nice to have that system today but hopefully I have learned my lesson. I think my parents said we still have to pay part of the bill even though I missed it.
    Quote Originally Posted by OldSpark View Post
    Yes, Justchat is paraphrasing what has been said before.
    But it is even more basic than that.
    Forget using the printer - don't you think there is something else wrong?
    I am certain it comes from an April edition of something else was published on an Australian Forum.
    The Aussies used to power things like solar powered torches (without batteries or caps) and cig plug dc-dc converters for charging your OWN flattery when caught outback (ie - no other batteries or vehicles around), but people got the joke. (That was before it became the "clever country".)
    Mind you, many did try soaking a certain Electronics Australia (April 197x) page trying to activate it's in-printed circuitry.
    What is the problem??
  2. #22
    Jan 2008
    in my old car, i had another simpler solution-- i put a switch to unlock the doors under the front end.
    i didn't use a waterproof switch, and never locked my keys in that car, so i kind of forgot about it until the switch corroded, and my doors kept trying to open one day..
  3. #23
    Raw Wave
    Nov 2009
    Quote Originally Posted by swinso View Post
    Got a spare cranking battery? (That's one hint.)
    In days past, I'd just carry a spare flat key to get in, in my wallet.
  4. #24
    Apr 2010
    The printer will be charged by the car when it is running but when it is off it will run off the internal battery.
    Security is not an issue because not body walks around parking lots with Bluetooth hacking software trying to connect to a Bluetooth printer. The car also requires a key with a computer chip to start.
    If my phone was also locked in with my keys I could get a friend to lend me their phone.
    I really don't see any problems OldSpark
  5. #25
    Raw Wave
    Nov 2009
    That's almost a cut&paste from your PM reply...
    So I didn't convince you in my PMs.
    As to not finding an unsecured wireless channel, maybe the people I know or hear of don't drive or walk past your neighborhood.
    But if you have insurance and it covers an unsecured vehicle it's not a big concern.
    Incidentally, my page-1 "security" comment referred to to PIC-code security as opposed to uPC (Audrino etc) code access.
    I'm glad to see that the inverter was irrelevant. Phew!
    So, another 24x7 printer. I'm glad it isn't the older full time thermals!
    Let me know when you replace the printer battery and what type it is (or costs) - I'm interested in the maintenance costs of this system.
    Let me know too if the printer battery fails before you need it.
    Good luck.
  6. #26
    tz1
    tz1 is offline
    Mar 2006
    Its all in the CAN (or maybe j1850)
    Depending on the make and model, opening the door usually happens via a message on the vehicle bus. For more recent cars, CAN, for earlier ones J1850. You can use an ELM327 device and monitor the bus to find the precise message (typically unlocking one door will cause its controller to send the message to the other doors). Sometimes there is no relay or solenoid except in the door itself, but if so then a reed switch or something far simpler would work.
    There are bluetooth versions of "OBD-II" devices for less than the printer, but they tend to pair with anything, so anyone that scanned it might be able to open the doors.
    A wifi router might be cheaper and more secure since you can use a stong password (one of the DD-WRT project APs). Then either go serial to OBD or find a LED you can light up and run it via transistor to the relay.
  7. #27
    Raw Wave
    Nov 2009
    Thanks TZ.
    I don't think swinso still sees any problem with his method and intent though....
    I did try though.... (via PM).
  8. #28
    Dec 2010
    You do a good job
    do a good job,thank you!
  9. #29
    Oct 2010
    So it uses a spare keyfob... Great, but what if *it* has a dead battery...
    "The car also requires a key with a computer chip to start."
    Which might be exactly what they have if you did not notice you left your keys in the car when you leave it on the local mall carpark...
    "If my phone was also locked in with my keys I could get a friend to lend me their phone."
    So you intend to keep the printer in "findable" mode? That way people do not even need special hacking software... Once they're in reach of the printer, it will show up as a new device! And most hardware TELLS you what brand and model it is, so guessing/finding the PIN would be trivial...
    If you do NOT intend to keep it findable, how would you pair a friend's phone with it?...
    Just a few practical questions I have...
  10. #30
    Raw Wave
    Nov 2009
    Been there. Tried that.
    But swinso sees no problem....
    FYI - Wendy is another topchinabuy.com spamster that joined today just so she could add her comment.
    I don't know why she bothered - we have already blacklisted topchinabuy.com...
    PS - I only just realised what theme this thread was posted under. I thought it was a serious project!
  1. 1994 Peugeot 106 XS beeing upgraded just a bit
    By boelle in forum Show off your project
    Last Post: 10-16-2010, 02:41 PM
  2. install mac mini
    By ssteger in forum VaultWiki
    Last Post: 02-09-2010, 03:47 PM
  3. USB Bluetooth on Car my car stereo?
    By janszoon in forum General Hardware Discussion
    Last Post: 08-14-2007, 04:53 PM
  4. VIA and Mini-box Announce First Sub-$300 Car PC Kit
    By Goofus in forum General Hardware Discussion
    Last Post: 03-13-2006, 12:28 PM
