Results 1 to 10 of 12
Thread: Ai10: controller for Apline AiNet
    Mar 2010
    Let me introduce my controller for different AiNet peripherals called Ai10. Initially is has been developed to let my other in-car controller to adjust major settings of Alpine PXA-H701 processor. However I tried to keep the board and firmware quite flexible for different hardware setups. Ai10 is controlled over RS232 (COM) or UART serial interfaces. It also could be connected to modern PCs thru various USB->COM adapters.
    Ai10 allows to monitor AiNet bus and send any packets to AiNet. Current firmware also has built-in commands for major PXA-H700/701 or MRA-F350 settings (volume/balance/fader/sub. kevel/input select) and AiNet CD Changers controls (change disk/track, play/pause).
    Boars schematics and firmware source are opened for community and available for download on Project Ai10 page https://sites.google.com/site/projai10/
    Further details about Ai10 project posted in this thread: http://www.mp3car.com/car-audio/1286...-solved-4.html
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I love the project whose the sources are opened !
    It's a great project !
    Mar 2010
    Thank you. Hope that someone will join and contribute the project.
    Dec 2006
    Would this allow allow me to use a MRA-F350 with a carpc? I'm wanting to use the optical out on my computer, but I can't seem to find a straight answer on this. That amp has the 17 band EQ that is controlled by the compatible headunits which also tell it when to turn on (no remote wire).
    Mar 2010
    Quote Originally Posted by zreon View Post
    MRA-F350 is supported as mentioned here:
    Alpine AINet CRC solved
    Ai10 would allow you to turn this amp on/off, set the volume and change the inputs. 17 band EQ is not supported yet, but you could borrow the HU to set up and store it.
    May 2008
    Bordeaux, France
    Does it possible to command the AINet interface by a RideRunner plugin in VB.NET . If yes what is my needs !
    Jan 2011
    Nik1976-
    I sent you an email from the Ai10 site as your mp3Car PM inbox was full. I am interested in obtaining one of your PCBs if you still have any available. Feel free to contact me when you have some time. Thanks for your hard work and dedication to this project!
    -Highly
    May 2008
    Bordeaux, France
    Hi Nik1976,
    Does exist a way to use this interface with a cda9835r for have an usb interface that read usb key or disk with mp3 files ?
    Mar 2012
    Hi, do you have controllers for sale?
    Sep 2008
    probably a little late on this and not quie understanding it all. but is anything still available from you? like boards, schematics, ect. so i can get a printed board and parts from digikey and make a controller. Id love to be able to control the 701 through your controller and a usb connection.
  1. Alpine AINet CRC solved
    By viper_1 in forum Car Audio
    Last Post: 05-12-2013, 05:28 AM
  2. Apline pxa-h700 harness
    By Kalt in forum Car Audio
    Last Post: 12-18-2005, 12:54 PM
  3. LCD Touchscreen Apline 7" Help for comp
    By DerekR in forum LCD/Display
    Last Post: 01-09-2005, 02:12 PM
  4. Replies: 4
    Last Post: 10-26-2004, 11:29 AM
  5. Alpine AiNET/Aux KV121 Pinouts
    By cybermob2 in forum General Hardware Discussion
    Last Post: 03-20-2004, 07:52 PM
