Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Intel Boards D201GLY vs D201GLY2 vs D201GLY2A Comparision Chart & Photos
    is back. FKA Robert Wray
    Fiberoptic's Avatar
    Jul 1978
    Baltimore, MD
    Blog Entries
    143
    As many of you may know the D201GLY was previously upgraded to the D201GLY2 adding a new south bridge as well as SATA ports. The Fan was also removed on this D201GLY2 revision. Intel has now announced and now shipping a D201GLY2A.
    We have called our Intel engineering team and confirmed that the only difference on the two boards (D201GLY2 vs D201GLY2A) is a fan. After taking the photos I can see a change to the cache heat sink, but that was not documented.
    As of today, both are in stock on the Mp3car Store.
    D201GLY - Discontinued
    Link for D201GLY2 (no fan) - Mp3car part MTB-053
    Link for D201GLY2A (fan) - Mp3car part MTB-054
    D201GLY Photo: (Full size here)
    D201GLY2 Photo:(Full size here)
    D201GLY2A Photo: (Full size here)
    May 2007
    Wichita, KS
    Just the fan between 2 and 2A? Whats the point of that? i guess just bulletproof cooling for the low power consumption version?
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    I added a fan that moves air across both of the heat sinks on my D201GLY2. It seemed warmer than I prefer while I installed the OS on the bench.
    TruckinMP3
    Read the FAQ!
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Me too. You couldn't comfortably put your hand on it. Adding even a tiny fan makes it barely warm.
    Want to:
    May 2007
    Wichita, KS
    Yeah i did too... i put it blowing down on the northbridge heatsink goes. i also replaced the stock processor heatsink with a smaller one. works great!
    Jun 2002
    Colorado
    Quote Originally Posted by Lithoss View Post
    What heat sink did you use and how did you remove the old one?
    TruckinMP3
    Read the FAQ!
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by TruckinMP3 View Post
    I didn't. I went ghetto and used a fan from a dead Via M10000. It fit snugly between the power supply board and the heatsink. It blows sideways across the heatsink. I suppose I should secure it with tape or something but it is in there nicely and I'll decide later if I need to do that.
    I reasoned (rationalized?) that if it falls off I'm no worse off than I was without it.
    Want to:
    Fiberoptic's Avatar
    Jul 1978
    Baltimore, MD
    Blog Entries
    143
    According to our sales rep some undefined chassis had cooling problems on the D201GLY2 inspiring the upgrade to 2A.
    Jun 2002
    Colorado
    Quote Originally Posted by Bugbyte View Post
    Goof, I was asking lithoss
    TruckinMP3
    Read the FAQ!
    Low Bitrate stroths's Avatar
    Jan 2008
    Dallas, Texas
    I ended up putting a cheap P3 socket 370 heatsink & fan I picked up at my local Fry's for $7. It's not low profile, but it is almost exactly the same dimensions as the original heat sink except I get a fan included in that height. The 50mm ball bearing fan is fairly quiet and it keeps the CPU cooler. The one I got is an Evercool CF-5B-H.
    Now I just need to find a similar solution for the other heat sink.
    There are some larger capacitors on either side of the processor, so you have to be careful to get a heatsink that will fit.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Intel MINI-ITX board - D201GLYL & D201GLY
    By jmbickham in forum General Hardware Discussion
    Last Post: 09-30-2008, 03:30 PM
  3. Intel D201GLY BIOS Petition, Mobo selection (C2D?) and test results!
    By Lope in forum General Hardware Discussion
    Last Post: 09-02-2008, 07:55 PM
  4. Intel boards
    By carpcguy in forum Classified Archive
    Last Post: 10-14-2006, 09:17 PM
  5. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 03:56 PM
