Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 61
Thread: Guru Double Din Car Computer All-In-One 1.83 GHz, Intel Core Duo
  1. #41
    Dec 2007
    Iowa
    I think that unit was already released and discontinued by Azentek. This is what i've gathered from what i've read. I think ur spending like 1500 extra for the convience of having a drop in. I think i have about the same specs with the exception of 4GB of RAM ( which i think would be a brutly hibernate resume) and it cost me about 1200 not including install parts.
  2. #42
    Jun 2005
    Burlington
    Does anyone know if the Guru features a startup/shutdown controller? Also, is the radio Tuner independent or can it be discovered via windows?
  3. #43
    is back. FKA Robert Wray
    Fiberoptic's Avatar
    Jul 1978
    Baltimore, MD
    Blog Entries
    143
    Quote Originally Posted by chris4851 View Post
    The radio tuner is windows integrated. The shutdown controller is a software applicatoin that runs on the guru.
  4. #44
    Jun 2005
    Burlington
    Thank you! So I assume that Centrafuse will integrate with the radio tuner.
    Is the software application for the shutdown controller an independent piece of software or with the built in windows power settings?
    Reason I am concerned is because I just received an Azentek Atlas CPC-1000 but it does not come with a front end, much like the Guru.
  5. #45
    Fiberoptic's Avatar
    Jul 1978
    Baltimore, MD
    Blog Entries
    143
    Radio integration with centrafuse is possible, but not is not under active support. Centrafuse might be able to assist you with that.
  6. #46
    Jun 2005
    Burlington
    Do you have a backup camera hooked up to the system? If so, does this device handle it with a separate input triggered by a reverse wire or is it software driven?
  7. #47
    Fiberoptic's Avatar
    Jul 1978
    Baltimore, MD
    Blog Entries
    143
    Backup cameras would probably be best exectued with a software switch.
  8. #48
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    That is the Azentec model, great Michigan based company. I've had my hand on the Azentec gps mirror also, quite impressive. From the looks of the hardware I see a very well built, stocky unit. Azentek has not pulled them out of production, it's more of an accounting issue, meaning the demand has to be there in order to fund further operations. So if I was not closing on a new house tomorrow i'd snatch one of these up.
  9. #49
    Jun 2005
    Burlington
    Agreed, I was told by Azentek that they had financing set up for production of the Atlas but that fell through once the economy went WAYYY south. Yes I do this this product will reach full production at some point but there is absolutely no knowing when they might be. I just hope that its not to far down the road because then a major redesign will be required because of new hardware.
  10. #50
    Jun 2005
    Burlington
    For anyone who has a Guru..... What front end are you using? I have installed Centrafuse and everything works perfectly with the exception of the radio tuner. I cannot find a pre-installed device that works with this radio. Any suggestions?
  1. Making a Car Computer; Need Your Help!
    By Fear Effect in forum Newbie
    Last Post: 08-18-2008, 10:51 AM
  2. Replies: 9
    Last Post: 06-08-2006, 06:15 PM
  3. Installing car PC in 1996 Honda Civic
    By PredatorCoder in forum Newbie
    Last Post: 08-18-2005, 08:58 AM
  4. Just for laught: Computer and Car
    By MatrixPC in forum Off Topic
    Last Post: 01-05-2005, 10:25 PM
  5. FS: Car Computer Setup - Everything you need!! Pics Galore
    By EBoundEE in forum Classified Archive
    Last Post: 06-19-2004, 10:41 PM
