Results 1 to 2 of 2
Thread: Xenarc MP-SC3 Power Cable Kit
    Newbie ploogle's Avatar
    Nov 2008
    Seattle, WA
    Just so I'm totally clear, this connects to the Car ISO thing, right? And it connects to the Audio Out/Headphone port and an AC port?
    More specifically, will it let me easily connect this computer to pretty much any car audio input? (Car ISO is a universal standard, right?)
    Jul 2010
    A "plug and play" power cable kit for your Mac mini! No more cable splicing!!
    Carnetix is pleased to announce the only "plug-and-play" power cable solution for the Apple Mac mini and your CarComputer application! The "MacPac" power cable kit connects your mini to the CNX-CA-P1900 DC-DC regulator to provide a quick and simple automotive installation. You are no longer required to cut and splice your Apple AC adapter (brick). The MacPac provides a pre-wired cable between the P1900 and the Mac mini, and includes all power and control signals necessary for full automatic startup and shutdown of the mini. The MacPac is fully compatible with the original Mac mini as well as the new Intel-based mini. (Note: Users of the CNX-P1900 V2.0 regulator and Intel-based mini will need to add a "resistor mod" to their P1900. Please check HERE for the P1900 V2.0 resistor mod).
    The MacPac kit includes a Y-cable adapter that is installed between the mini's power button and the motherboard. This allows you continue to use the original Mac mini power button as well as the P1900. The MacPac and Y-cable allow you to easily remove the Mac mini from the car so that you can take the mini inside for software tweaking or updates. When indoors simply use the AC adapter that came with your mini.
    The MacPac also provides access to the P1900 secondary output, DelayOn amp control, and ground via seperate wires.
    __________________________________________________ ________________________
    Pallet Racking | Fitflop Boots
  1. Xenarc 702TSV torn flex cable after custom fit
    By STI_FFY in forum LCD/Display
    Last Post: 07-03-2009, 08:10 PM
  2. 2007 Ford Fusion Carputer (version 2.0)
    By FusionFanatic in forum Show off your project
    Last Post: 04-20-2009, 04:56 PM
  3. Xenarc Power Cable - Which is Positive/Ground?
    By noobified in forum LCD/Display
    Last Post: 07-06-2008, 11:06 AM
  4. Replies: 1
    Last Post: 11-17-2007, 07:30 PM
  5. Xenarc - USB Power cable?
    By Coeus in forum Power Supplies
    Last Post: 01-13-2005, 08:07 PM
