Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Looking for a schematic for the momentary led push button switch.
  1. #11
    Raw Wave
    Nov 2009
    It sounds like a resistive dimmer, and that you need to connect transfer the LED connections - ie, instead of +ve to +12V and -ve to dimmer, +ve to dimmer & -ve to GND (or vice versa).
    (Not that resistive dimmers work well for LEDs, but with bulbs this is effectively a "voltage" dimmer.)
    (And on 2nd thoughts, it should be the same for modern (PWM) dimmers....)
  2. #12
    Raw Wave
    Nov 2009
    FYI - PWM dimmers seem common in modern Jap vehicles.
    I pulled a couple from 1995 & 1996 Hyundai Excels. They use a 10A switching MOSFET and appear to be PWM because there is negligible heat when dimming a 50W halogen bulb, and a parallel 12V LED dims in proportion.
    I might find out how to reduce it lower dimming limit but otherwise probably won't bother deciphering the circuit - I think it's easier transplanting my old 555 circuit which uses ~10 fewer components, but the same 10k pot and FET switching.
    It has a +12V & GND connection with the output being GND PWM dimming (ie, LEDs & lights to +12V and grounded through the dimmer's 3rd terminal).
    I have little doubt similar circuits feature in other Jap vehicles...
  3. #13
    Jan 2008
    ^ those have become a quiet led hobbyist trick-- to pull the oem pwm units from import cars...
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
  4. #14
    Raw Wave
    Nov 2009
    Phew! Good to see!
    I've had no need - I've had my old circuit etc. (It's now 4 years since I disassembled my 12V camping fluoro to insert my dimmer that was scheduled for ~6 years ago!)
    And IMO it's kind of surprising considering the... er, "debate" I had a few years back with an "experienced expert" installer etc on here... (At least this "reality" was only 10 years ahead of my debatees unlike fresh graduates that have been 20 years behind!)
    But it was only whilst accompanying a mate to a wreckers that I happened to notice... and thought...
    Oh dear - I forgot to find out their price....
    But as a convenient matchbox-sized ready built PWM dimmer - and I suspect easily upgradable to 100A...
    I might just reassemble my flouros. Make series plug-in dimmer instead... (Yeah, why get up to dim a light when the dimmer cam be beside you. Geez I'm so stupid....!)
    And I like the "quiet led hobbyist trick". Oh poo - should I delete all now?
    But yeah, there are those that know and watch the others....
    For me it confirms the brilliance (pun intended) that I know some have. And I skip any dim-wit.
  5. #15
    Constant Bitrate Project07MACry's Avatar
    Aug 2009
    BK, NY
    Hallelujah! I thought I was the only one going through this!
    I too was able to get the buttons to permanently light. However, is anyone familiar with getting them to light when the device (i.e. Mac Mini) is on? Any input is greatly appreciated!!
    All systems are a go...
    Currently in "tweaking" mode.
    The Worklog
  1. Momentary switch to port replicator power button
    By hardcoreracing in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 02-14-2008, 10:31 AM
  2. Low Profile Push Button Switch
    By anonim in forum General Hardware Discussion
    Last Post: 08-03-2007, 05:47 PM
  3. Push button SPDT switch?
    By muldrick in forum General Hardware Discussion
    Last Post: 07-02-2007, 01:23 AM
  4. Turn Constant 12V to a momentary push w/ voltage change
    By KyleYankan in forum Hardware Development
    Last Post: 03-25-2005, 10:33 AM
  5. 4 pole push button switch, in on or off position
    By johnny010 in forum Power Supplies
    Last Post: 04-15-2003, 07:01 PM
