Results 1 to 9 of 9
Thread: xm devices on mp3car.com
    Constant Bitrate Perrosky's Avatar
    Feb 2006
    NJ
    HELLO guys I'm about to install my car pc, and I want to install xm satelite radio on my car too using RR as my front end. Can you guys tell me what's the diference between the XM DIRECT UNIVERSAL TURNER/Mp3Car USB adapter for XM Direct.
    http://store.mp3car.com/category_s/55.htm
    I really want to know a little about the instalation of each on, and wich one work better with road runner. I have allready a satelite radio reciever that I get fron b3stboy if that helps.
    thanks
    One of the best way to learn is making mistakes, But much better when you learn from someone else mistakes
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    You need the XM direct box to receive the XM signal with any solution you choose.(The adapters do not work with other receivers). Both solutions will work equally well with Roadrunner. The USB adapter is used in lieu of a home made cable solution discussed here in the forums. It is how the data is sent to your PC. I and several others here use the home made solution that connect to a com port on your PC with no problems. The MP3car solution is well spoken of as well and goes directly to USB. I hope this helps and if it is not accurate please correct me.
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
    _
    Mar 2004
    Little Elm, Texas
    I edited your link to be correct. You had another http:// in there.
    Jan Bennett
    Feb 2006
    NJ
    So it I buy the XM DIRECT UNIVERSAL TURNER I can make it work with this device that I have allready or do I need something else. I'm sorry I just have not figure it out how to set up and what do I reallu need to make the xm work with the carputer.
    PS. THANKS REDGTIVR6 for the correction
    _
    Mar 2004
    Little Elm, Texas
    You buy the USB adapter to make it work with the computer. However, you have to have a front end that can utilize the driver for it.
    Jan Bennett
    Feb 2006
    NJ
    So what u're saying it's that I need to buy both devices to make it work with the carputer the DIRECT UNIVERSAL TURNER (wich it the one that recieve the xm signal) and the Mp3Car USB adapter for XM Direct (the one that make it able work with the carputer?
    _
    Mar 2004
    Little Elm, Texas
    Yes. You need both devices or you make your own cable like some have done here on the forums.
    Jan Bennett
    Mar 2007
    where is the thread that shows you how to make your own cable if you want to try it?
    Mar 2007
    Central Florida
    If I'm not using a front end, how do you actually use the satellite radio after you have installed the hardware?
  1. Replies: 49
    Last Post: 07-30-2006, 01:10 AM
  2. FS: Xm Cables, XM Home Cable, USB-Serial Adapters
    By Legarcondemerde in forum Classified Archive
    Last Post: 07-08-2006, 07:15 PM
  3. XM Channel Changes
    By Chuck in forum Road Runner
    Last Post: 04-05-2006, 05:33 AM
  4. Sirius vs. XM...? what up Gee?
    By mindscream in forum Car Audio
    Last Post: 10-24-2004, 04:31 PM
  5. Using an XM direct as an XMPCR
    By dacndar in forum General Hardware Discussion
    Last Post: 10-17-2004, 02:21 AM
