Results 1 to 5 of 5
Thread: USB XMDirect adapter DIN cable pinout
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    bought a used XM Direct USB adapter, and I think I received the wrong 8 pin cable, cause when I plug in an XM direct, I blow a fuse.
    I checked the pinout of the cable I have and its not pin-pin.
    Anyone know if it should be, or know the pinout?
    Thanks in advance.
    TruckPC - gutted, being used for test setup
    BoatPC - off season - Inelmac screen needs serviced again!
    BlazerPC - last vehicle PC I'll build
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    Is this what you are looking for? It is the 8 pin cable but for serial connection.
    http://www.mp3car.com/vbulletin/hard...ter-guide.html
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
    Mar 2004
    Greenacres, WA
    no looking for the cable that comes with the USB adapter that is sold at the mp3car store,
    thanks for trying to help!
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Are you sure the 12v wires aren't backwards?
    Want to:
    Mar 2004
    Greenacres, WA
    yep, checked that.
    When just the MP3Car USB adapter is plugged in, no problem. However when I connect the XMDirect, fuses give out.
    The 8 pin Din cable I received does not connect 1-1, 2-2, etc. So I'm trying to find out if the cable should
  1. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 12:49 PM
  2. Bytecc BT-200 USB 2.0 to IDE Adapter power?
    By hauler34 in forum Input Devices
    Last Post: 11-07-2006, 02:02 PM
  3. Plug and Play High-Speed USB 2.0 to IDE Cable adapter for just $12.49
    By srcstc in forum General Hardware Discussion
    Last Post: 06-07-2006, 03:35 AM
  4. XM Direct digital adapter or XM PC cable with SkyFi2???
    By LATEOTT in forum Hardware Development
    Last Post: 01-19-2005, 03:18 PM
  5. GWC UD-200 USB 2.0 High-Speed to IDE-ATAPI Adapter Cable
    By orangewhip in forum General Hardware Discussion
    Last Post: 04-13-2004, 06:29 PM
