Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 45
Thread: Help translating neocar media center
  1. #31
    Belgium - Oostmalle
    Hi guys,
    I finished the translation of NSL_DU.xml . Just checking in NM etc. to see if the translations fit in the interfaces. I'll try to fiddle around with words to make them fit. Hope to finish it tomorrow. Anything else to translate? (only for NMC please, I received my Sproggy and want to make it work also ...)
  2. #32
    Oct 2003
    Copenhagen, Denmark
    Should we translate the parts in the general section, looks like parameter difinitions to me, but i could be wrong ?
    Not doing carpc anymore
  3. #33
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    Wow, that's fantastic gyro!
    I'm experiencing the 'erreur inattendu' problem at the moment, so I can't test it out
    Sorry you had to do it alone, I'm really ashamed I couldn't put more time in it...
    Joa
  4. #34
    Belgium - Oostmalle
    Quote Originally Posted by JC-S60
    Joa
    @JC-S60 :
    No problem, we're all too busy with lots of things ... I noticed some people get this error. When I finish my hardware I'll try to help if the issue isn't solved by then.
    @Netsuo :
    Found another problem in Neocar Manager; If you go to the keyboard option and click the keyboard shortcut manager you receive an error 35604 when you select another option on the left and go back afterwards. Also in the keyboard shortcut manager the informations box does not get updated (normally it is blank in the xml file, but your buffer doesn't get emptied).
  5. #35
    Belgium - Oostmalle
    Quote Originally Posted by _dopehead_
    Yes, you have to, but be sure you use the same names at the bottom part of the xml file (the words with the % sign in front)
  6. #36
    Maximum Bitrate netsuo's Avatar
    Jan 2003
    Switzerland
    The new error with keyboard part is that this config module is not activated.. It's only in devloppment yet
    Lots of thanks for the translation.. it's a little bit hard for me to respond to all, i have lot of job so please apologize for any inconvenience..
    It will be better if i can have a dedicated forum to talk about neocar...
    NS - neocar suite
    http://www.neocarmediacenter.com
  7. #37
    Belgium - Oostmalle
    Quote Originally Posted by netsuo
    The new error with keyboard part is that this config module is not activated.. It's only in devloppment yet OK
    Lots of thanks for the translation.. it's a little bit hard for me to respond to all, i have lot of job so please apologize for any inconvenience.. No problem
    It will be better if i can have a dedicated forum to talk about neocar... I AGREE !!!
  8. #38
    Belgium - Oostmalle
    Translation in Dutch
    Hello guys,
    Here is the finalDutch translation (finally). If anyone finds some bugs, please let me know, so I can correct it.
    Attached Files Attached Files
  9. #39
    Variable Bitrate aguila's Avatar
    Jun 2004
    the Netherlands
    I like to try, with which version of Neocar should I use it?
    MII 6000; 256 MB; lilliput touchscreen; 40GB; bluetooth SE 68i; software still experimenting switched from mediacar to frodopayer, phonecontrol, destinator 3 (NM), and others.
    http://www.mp3car.com/vbulletin/show-off-your-project/31991-audi-tt.html
  10. #40
    Belgium - Oostmalle
    Quote Originally Posted by aguila
    Read the forum ...
    It is in this thread :
    New neocar media center with neocar installer
    Happy testing
  1. windows xp media center edition
    By the_spy_guy in forum XP MCE
    Last Post: 04-15-2006, 03:26 PM
  2. Mobile Media Center (NEW SOFTWARE!!)
    By HybridMike in forum Software & Software Development
    Last Post: 12-08-2004, 10:32 AM
  3. neocar media center EN version, here it is :)
    By netsuo in forum NeoCar Media Center
    Last Post: 10-04-2004, 01:36 PM
  4. My upcoming media player: neocar media center
    Last Post: 10-04-2004, 10:15 AM
  5. Software for controlling a TV media center
    By the_new_guy in forum Software & Software Development
    Last Post: 07-07-2004, 11:31 PM
