Any help to make German or Spanish translation ?
For those wo don't know, neocar media center is multilanguage as for now
So, if you know another language, if you have time and if you want to help me, you can make translations for me
Feel free to correct some bad translations on english file
I think the file is self explaining, you only have to translate te texts IN the XML structure (but not the structure itself).
Thanks in advance for any help.
Please go to this thread to download the last language file:
Translations
NS - neocar suite
http://www.neocarmediacenter.com
NS - neocar suite
German or spanish will be a bit difficult, but I'll give dutch a shot![]()
Yeeeessss
Really coolKeep me informed
NS - neocar suite
if you need help to look at a Dutch draftversion I am happy to do so
MII 6000; 256 MB; lilliput touchscreen; 40GB; bluetooth SE 68i; software still experimenting switched from mediacar to frodopayer, phonecontrol, destinator 3 (NM), and others.
http://www.mp3car.com/vbulletin/show-off-your-project/31991-audi-tt.html
I'll send you a copy when (if) finished the first attempt
@netsuo: I already discovered a little error in the french version. At <msgNoHibernate> is says 'going to hibernate' instead of 'cannot go into hibernate'
Or I am terribly wrong![]()
I can speak Spanish but I'm not sure I will have time... Any idea how many phrases/words need to be translated? Bytheway going to finally load the English version on my PC today![]()
Installed.
-GPSSecure- - GPS Tracking
translating is approximatively 500 lines
If you have time (and motivation), make it. Otherwise, there's no problem
@JC-S60: if you find errors, you can make corrections directly on NSL_EN.xml and then send it back to me
Thanx at all for your help![]()
NS - neocar suite
I guess I could have just looked at the file you have linked above and answered my own question. Doesn't look like it would be too bad. Would take forever but I don't do anything at work anyways so I could probably do it. Only problem is my Spanish isn't perfect so if there is someone that has the language mastered, and that would do it, they should do it. If no one else is up for the job then I can probably do it. I can speak it fluently but not sure how well I can putting it in text. I can just use a dictionary to make sure I get the spelling correct.Originally Posted by netsuo
One question: can I use any ASCII characters with the translation?
Installed.
I get an "unexpected error" whenever I try to run the program, both before doing the update and after....any ideas?
J'obtiens "unexpected l'error" toutes les fois que j'essaye d'exécuter le programme, avant de faire la mise à jour et ensuite. Des idées ?
*J'ai donné à Français un essai, mais il peut être éteint terriblement. Si oui, je fais des excuses. I've seulement pris environ 3 ans du français dans ma vie.
