Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 54
Thread: New neocar media center with neocar installer
  1. #31
    Jul 2004
    i found a problem in the current build.
    i went and did the album management for all my mp3s and had it make the description.txt and when you select a album in nmc its showing html code and i opened the description.txt and its all code
  2. #32
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Netsuo!
    Unexpectged error fixed for me!
    More detailes to follow... I'm not really sure what was done, lemme think a bit...
  3. #33
    São Paulo, Brazil
    Well the last things that I can track down that I have donw was fiorced install of vb6fr.dll (registered and put in windows/system32) and then reboot (I remember copying the file and it not working, I then rebooted only on the following day), and then the other thing that I installed was HeadUnit (PyCar).... and now magically it works...... So if someone can try the above and maybe we can track it down... the vb6fr hunch looks liek it makes more sense but who knows...
  4. #34
    Super Moderator xBrady's Avatar
    USA
    Quote Originally Posted by RoyN
    Makes sense if the installer doesn't come with all the necessary .dll files. I'll have to check it out tomorrow.
    Installed.
    -GPSSecure- - GPS Tracking
  5. #35
    São Paulo, Brazil
    For more dubgging info, here is what was installed on the machine AFTER nmc, but prior to noticing that it was working again...
    DVD Decrypter
    SimpleDivX Codec (from free-codecs.com)
    XviD Codec
    HeadUnit 0.3
    I am positive that a full reboot is necessary somewhere along the line because I recall NMC not working and then starting to work just after a reboot.
    Dependency Walker showed nothing different now that it is working.... Really useful that was!
    Good luck all!
  6. #36
    Maximum Bitrate netsuo's Avatar
    Jan 2003
    Switzerland
    i will check in headunit what files are suppoosed to be used in NMC..
    Lots of thanks for your "pseudo-debugging"
    NS - neocar suite
    http://www.neocarmediacenter.com
  7. #37
    São Paulo, Brazil
    I'm about to try and reproduce the success on my carpc (not installed but still the CPU that will go in the car)...
    It is now running a slim windows xp install (done with nLite... Install size went from 500 to 180mb)
  8. #38
    São Paulo, Brazil
    No good... Installed HeadUnit no go, installed dvd decrypter no go... installed codecs, no go.... cant track down what i did... this is so frustrating!
  9. #39
    Jan 2003
    Switzerland
    the same thing i had
    No way to find whats changed.. and with this plenty of system DLL's, it's sooo hard to find...
    NS - neocar suite
  10. #40
    São Paulo, Brazil
    Netsuo, can I suggest you post this in a VB forum or developer forum? I'd post but they might ask about coding or librares, an since I dont have the source I wouldnt be able to answer...
    I'm gonna go check MS knowlege base, but if you can try and check a forum then we can probably get it sorted....
  1. windows xp media center edition
    By the_spy_guy in forum XP MCE
    Last Post: 04-15-2006, 02:26 PM
  2. Help translating neocar media center
    By netsuo in forum NeoCar Media Center
    Last Post: 11-09-2004, 03:25 PM
  3. neocar media center EN version, here it is :)
    Last Post: 10-04-2004, 12:36 PM
  4. My upcoming media player: neocar media center
    Last Post: 10-04-2004, 09:15 AM
  5. Software for controlling a TV media center
    By the_new_guy in forum Software & Software Development
    Last Post: 07-07-2004, 10:31 PM
