Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 47
Thread: [OFFICIAL THREAD] NMC 0.7 alpha.1 bugs
  1. #21
    Belgium - Oostmalle
    Installed VB6 runtimes. .NET version is1.1 .
    In NM --> Audio Options --> Albums Management : After search for an album : If you double click to show the album details, the following error occurs (first image)
    EDIT
    After adding msinet.ocx to system32, all is ok. In the details window there is a bit of garbage above the picture.(second image)
    Car : Hyundai Tucson
    Carpc :
    Lilliput 7" touchscreen indash 90% done
    PSU : M2-ATX
    Epia M10K /512DDR/80GB Maxtor
    Software : Windows XP Pro 100% done
    RR with DigitalFX skin
    In car : 80% done
  2. #22
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    download this http://www.santanacreations.com/needed_files/msinet.zip unzip into c:\windows\system32 and go to start->run "regsvr32 c:\windows\system32\msinet.ocx"
  3. #23
    Belgium - Oostmalle
    Quote Originally Posted by RoyN
    Thanks RoyN, I already copied it from my v065 install to system32. It isn't really nescessary to register the file (but it doesn't hurt ...)
    Carpc :
    PSU : M2-ATX
    In car : 80% done
  4. #24
    I'm getting a code 48 can not find winamp.dll. Opon further inspection, ithe file is showing as 0kb.
  5. #25
    São Paulo, Brazil
    I'm getting type mismatch 380 when entering NM.... cant get into NM at all...
  6. #26
    Maximum Bitrate pyros's Avatar
    Mar 2004
    Toronto, Canada
    i can't figure out how to chagne the location of your mp3s/videos after you've installed NMC? I've checked in NM and I can't find it, am I missing something?
    edit: also the location for the videos is defaulting to whatever the value for audio is.. it even says "Audio | .... "
    edit2: when i double click on a visualsation the winamp AVS editor appears in the background and wont go away :P
    Thx
    2004 Ford Mustang Mach 1
    Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
    Install Status: DONE
    My XM FAQ
  7. #27
    Maximum Bitrate netsuo's Avatar
    Jan 2003
    Switzerland
    Your folders are to configure in NM (see general section).
    The AVS is NOT supposed to be configurable by double click, the only options you can configure are in NM.
    NS - neocar suite
    http://www.neocarmediacenter.com
  8. #28
    Belgium - Oostmalle
    Quote Originally Posted by JC-S60
    Change that sig. gyro, from "hungry waiting for" to "enthousiastically testing"
    Done
    Carpc :
    PSU : M2-ATX
    In car : 80% done
  9. #29
    Jan 2003
    Switzerland
    As i was thinking, you got lots of bugs.
    But what are you thinking of the rest ?
    NS - neocar suite
  10. #30
    São Paulo, Brazil
    NMC is much better now! It ismuch nicer than the 07 preview I had, and for sure MUCH MUCH nicer than the 065 that the others had!
    Keep up the good work! any word on my problem entering NM? I cant go into it...
  1. neocar media center 0.7 alpha.1 : here it is
    By netsuo in forum NeoCar Media Center
    Last Post: 11-21-2004, 01:44 PM
