Page 4 of 9 FirstFirst 123456789 LastLast
Results 31 to 40 of 87
Thread: Requests / Suggestions
  1. #31
    Belgium - Oostmalle
    Netsuo, are you planning te rebuild the installer ?
    Could you insert an uninstall too? Not that I am planning to uninstall it, but it could be usefull (or can we delete the NMC map the Windows 3.1 way?)
    Car : Hyundai Tucson
    Carpc :
    Lilliput 7" touchscreen indash 90% done
    PSU : M2-ATX
    Epia M10K /512DDR/80GB Maxtor
    Software : Windows XP Pro 100% done
    RR with DigitalFX skin
    In car : 80% done
  2. #32
    Maximum Bitrate netsuo's Avatar
    Jan 2003
    Switzerland
    i think i will change my install system.
    I have a problem, NMC use VB6 DLL's but my installer too, so my installer is ****. I will then use nullsoft install system (i allready made a script) that will load a config assistant directly after installing the required files.
    I think this is the best solution (nullsoft installer is free, fast and all OS compatible).
    NS - neocar suite
    http://www.neocarmediacenter.com
  3. #33
    The SkinFather febsperanza's Avatar
    Feb 2003
    Please make the title_track in the photo modules scrollable. NMC crashes if the size of the title exceeds the space provided. Thanks!
    Brushed Metal Skin
    http://www.geocities.com/febsperanza]
    MIA at the moment
    [please email me instead of pm]
  4. #34
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    The nullsoft installer is a good way to go!
  5. #35
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    When playing music in full screen mode, is it posible to keep the song name/info showing. Currently it disappers with the buttons.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  6. #36
    Maximum Bitrate wysocki's Avatar
    Mar 2004
    Los Angeles Area
    Haven't seen anything about XM support. Yes/No/When?
  7. #37
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Not sure when XM will come or IF it will come because the main developer (and only developer) is in europe, XM is only available in the US... Difficult to test and all...
  8. #38
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Hi fella.. would it be possible to get rid of the '%' after the volume amount, as its quite have to fit it in using some fonts when skinning.
    cheers
    CdR
  9. #39
    Jan 2003
    Switzerland
    i'll do. Right now.
    NS - neocar suite
  10. #40
    Dec 2003
    New York
    any answer to my question above? Can it be achieved with different a skin.
    Also can you make a skin thread which is a sticky. This way we can find all the skins at one place. There are some really good skin being made.
    Installed
  1. D3 Front End: Enhancements/Feature Requests
    By Dominik in forum Map Monkey
    Last Post: 12-28-2004, 03:44 PM
  2. Suggestions on painting a desktop pc....
    By falconey in forum Off Topic
    Last Post: 09-29-2004, 06:12 PM
  3. suggestions
    By Jaimz in forum Power Supplies
    Last Post: 09-28-2004, 05:08 PM
  4. Suggestions / Requests
    By LESLIEx317537 in forum FrodoPlayer
    Last Post: 07-29-2004, 01:23 AM
  5. DVD Interface Question (Looking for suggestions)
    By GTC in forum Software & Software Development
    Last Post: 06-12-2003, 09:44 AM
