hmm okay..
I use ViaMichelin MapSonic, so I ccan't use the maps.. can I??![]()
I think this will come only when netsuo decides which one and to implement ntegrated navigation... i think ho chose freedrive
hmm okay..
I've got a request
Make NMC hide or stop video and viz playing when handbrake is off
So when your driving video and viz won't play (have a option of selecting if you want viz or video turned off)
this way when the handbrake is down the cops can't crack it at you cause you can't play video
i'll works by shorting 2 pins on the serial port which is then connected to the handbrake.
this is a nice option for people who want to abide by the law or want this safety feature.
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
Ok another request but its a very simple request
Add a command to move to the last file in the directory.
This will allow abutton to be added or a longer press action to be added so when u push it it jumps to the last file of the dir
So when u do the code you will have end-dir + next-track which will skip to the next album
just an easier way to skip to the next album without hitting next alot or going out fo the dir and selecting the next directory.
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
Stric --> It's a bug on this version of NMC, it should be working (hopefully) in the next version, which should be out in the end of this month.
I'm using music videos to.. so i'm waiting to for the next version![]()
licensed wma support
via epia sp13000 mobo
512mb ddr ultra slim ram
100 gig hdd
mp3car in-dash TS
much more to come!
