i ran the installer then it extracts all the files then that's it...
no rosponse. nothing happens then. is this only me? why?
i have p4-2.8 512mb xp sp2
ALPHA 1c BUGS:
NMC:
- When playing a WAV, NMC shows the last played MP3's infos
- When playing a audio file, i get sometime i error 5 while selecting a NPL playlist in the filelist module
- WMA icons not showing in the filelist module
- When playing a NPL playlist with folders, when the file is passing to the next, a bad file is played (not the next)
NM:
NSW:
- BIG ERROR: NMC is not reloading the base skin resolution so when saving NMC crashes
IMPORTANT: READ THIS CAREFULLY -> http://www.mp3car.com/vbulletin/show...398#post314398
NS - neocar suite
http://www.neocarmediacenter.com
Netsuo, if you set a base resolution in a skin with NSW, it always resets to its original settings. It seems the new resolution is not saved. Can you check this? I want to see your light skin at 1024x768. Probably I can set it by hand also in the xml of the skin, but just want to know if it works on other pc's.
<edit>
I checked. In the xml file of the skin, the resolution is set as it is saved. Only if you open the informations in NSW, it seems there is always standing 800x600, and not the resolution that is in the xml file of the skin. Solved my second problem too. I had to set the resolution it displays on my screen in the skin section of NM. (stupid me)
</edit>
Car : Hyundai Tucson
Carpc :
Lilliput 7" touchscreen indash 90% done
PSU : M2-ATX
Epia M10K /512DDR/80GB Maxtor
Software : Windows XP Pro 100% done
RR with DigitalFX skin
In car : 80% done
You can set the skin resolution in NM, in the skins options
In NSW it's only the physical skin size (to be entered originally by the skin's designer).
NS - neocar suite
I noticed sometimes the date disappears in the audio module ( after switching to other modules and back). Have to figure out when it exactly happens. I'll let you know.
Carpc :
PSU : M2-ATX
In car : 80% done
Carpc :
PSU : M2-ATX
In car : 80% done
If I go to the module photos and click the photo, it goes full sreen with audio bar. Clicking again is real full screen and if I ckick again to go to mormal mode, I get an error : erreur d'execution '340' L'element du groupe de contrôles '247' n'existe pas.
Carpc :
PSU : M2-ATX
In car : 80% done
1b: Light Works
1c: Light Works
1b: Onyx works
1c: Onyx broken
Run-time error '9':
Subscript out of range
Any ideas what might have changed?
2001 Pontiac Grand Prix GTP Sedan (Sold)
2007 Scion tC
WhereIsMyGPS.net Online Tracker
http://www.cardomain.com/id/leddy
read the post about skin physical resolution. Open NSW and go to the skin infos![]()
NS - neocar suite
