Results 1 to 10 of 11
Thread: Skinning issue.
    Jun 2003
    Memphis - TN
    Skinning issue.
    Every time I select the images for my Main menu module, I dont ever see
    anything.
    Is there something Im missing, or am I bugged?
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    Maximum Bitrate netsuo's Avatar
    Jan 2003
    Switzerland
    Please more explain i cant figure what you say
    NS - neocar suite
    http://www.neocarmediacenter.com
    Jun 2003
    Memphis - TN
    I open skin workshop.
    Create a new one.
    Under the properties I set the images for the main module.
    I never see the images. If I open the skins folder itself, They are there, but not when I edit.
    If I open your skin, and change the files with my own pictures, then it works.
    Jan 2003
    Switzerland
    have you copied your skin images to the skin folder ? (NMC_folder/skins/your_skin)
    named MENU_EMPTY.png (or JPG, GIF, BMP) MENU_OFF...
    NS - neocar suite
    Belgium - Oostmalle
    Which image format is preferred? png and jpg are smallest in size? But are they the sharpest?
    Car : Hyundai Tucson
    Carpc :
    Lilliput 7" touchscreen indash 90% done
    PSU : M2-ATX
    Epia M10K /512DDR/80GB Maxtor
    Software : Windows XP Pro 100% done
    RR with DigitalFX skin
    In car : 80% done
    Jan 2003
    Switzerland
    i think the better quality / size / NMC useability is PNG
    NS - neocar suite
    Jun 2003
    Memphis - TN
    They are in the skin folder, I guess when I selected them, it copied them over?
    but they are there.
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    I think you need to move them manually to NMC/skins/custommx3/ (assuming that is the name of your skin... I saw it in the screen shot you posted)...
    Jun 2003
    Memphis - TN
    I did, same issue. (even though they were already there)
    Jan 2003
    Switzerland
    try to use other filenames or set these in lower case.
    (i say something why dont really see what's happening )
    NS - neocar suite
  1. Skinning tutorial?
    By erazor in forum FrodoPlayer
    Last Post: 11-06-2004, 07:36 AM
  2. Is skinning FP as easy as Winamp ??
    By Don 944 LA in forum FrodoPlayer
    Last Post: 09-27-2004, 09:52 AM
  3. More of a PSU/Inverter issue
    By slasherx in forum Power Supplies
    Last Post: 08-11-2004, 06:14 PM
  4. Few Skinning Questions..
    By [iG] in forum FrodoPlayer
    Last Post: 07-02-2004, 06:58 AM
  5. Opus power supply issue
    By dmazyn in forum Power Supplies
    Last Post: 10-15-2003, 06:32 PM
