to give you a better idea of what I mean, here a pic of what I need the window for.. everything inside the red square is D3 (skinned of course)
Lo fella.. I know you have alot on your plate.. but would it be possible to create a external app, that you can configure the embedded window, like you can the embedded filelist, so you can put buttons round it ?
This is my idea anyway below.. At the moment D3 sits above the skin, rather than in it.
i know what you want to make. Before actual system NMC was created to work as you want.. but i've changed for some code reasons.. Must see if i can find a way to make this available![]()
NS - neocar suite
http://www.neocarmediacenter.com
Sure it can be done pretty easily, just use windows api to make the Des a child of the app that you want, and then use the sendmessage api to configue the widh hight and frame style...
Man, i allready have a "apps embedding" function working with API's, but what i say is just "i must see HOW i can include this function in NMC to make it simple to use and to configure"![]()
NS - neocar suite
Wouldn't this affect the update speed of D3 though? I've noticed that 1.1.3 has some kind of latency problem as my position on the map is roughly 2secs / 30yds behind actual position where 1.1.2 was spot on. 1.1.3 also seems to take longer to load and will not embed in MediaCar on my setup no matter what I do.
*** Having said that though, I'm now using NMEA on 1.1.3, and 1.1.2 uses Sirf...
John
My Nissan 200SX @ Silverstone
NOW SADLY WRITTEN OFF!
My Car's spec list + pics
Stealth CarPC fab'ing...
On my system Desti3 is not affected by the embed... it work perfectly![]()
NS - neocar suite
Why are you using the D3 front end rather than embedding the D3 object in your application directly?
If I understand the D3 frontend is a stand alone application, if you wanted to you could just integrate the actual D3 core functions directly into your own application?
I use D3 frontend rather than embedding it why i dont have any time to make this yet. This will come with release 0.8 of NMC.
I wish to finish some functions before starting to embed any GPS software.
NS - neocar suite
Right, but if you had all the time in the world you would embed it into the application directly right? I'm doing the same thing the applicaiton that I use and I just want to make sure I'm heading down the right road.
