yes, thatīs right.
It crash with following error:
Printable View
yes, thatīs right.
Exactly.. thx m8 :)Quote:
Originally Posted by C1500
Hi, me again...
Next "bug" or problem:
Equalizer doesnīt work (maybe only on my skin, but why?)
Is any software required for the EQ? (.net / winamp/ mp9)
Nothing happend, when you push the button in Audio-Menu
NMC crash with "error 424" when you push the button in Video-Menu.
See ErrorPix:
equalizer is currently deactivated for "recoding" reasons. Sorry.
all right,
then there will be a hardcortest of the other funktions ;)
Right well it remembers the last module, but it dosnt remember the last song you were playing. I have to enter another module like pictures then go back into audio and play the song, then it rmembers the song. Neo?
Just tested it out, when playing a divx movie, when I use the neo controls to control volume, it will proceed down to 76 and then next click jump back to 99, 76 is as low as I have been able to get it...
@Motoko: please try these two things.
1. I guess NMC restarts with pause, so try to push the play button.
2. Maybe only the volume is down to "0", try to tip on "vol+" on startup.
Try these befor u change to Pix-Menu and back.
@septicdeath
is these problem only during divx-playback or all time?
witch codec do u use?
regards
Peer
Only with DIVX .avi's . Im using the Nimo codec pack. v.31 I believe. I'll try messing with it/try another one to see if that helps. Also, when I use the video browser to load a dvd from a hard disk file (e:\movietitle\VIDEO_TS\VIDEO_TS.VOB or any of the files I get a error box with a Run-Time error '6': Overflow.
These files however run fine from the original DVD (ripped with DVD Decryptor) but none of my hard disk versions work, all the same error. Files are fine, checked with multiple other front ends and stand alone players with no issues. Thought I would let you know...
