Results 1 to 10 of 10
Thread: How to add GPS support?
    May 2005
    Hi there,
    Ive been searching on the forum about this topic with no luck. I would like to use mapmonkey embeded into NeoCar the same way you can do so with RR... is that possible?
    Thnx
    FLAC NiN^_^NiN's Avatar
    Aug 2004
    Australia, Melbourne
    it's possible im at work so i'll tell you how to do it if no1 else does by the time i get home.
    you should look at the external.xml file in the app folder (atleast i think thats right)
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
    Jan 2005
    try this >> (make some changes for destinator like the drive and filename)
    <?xml version="1.0" encoding="ISO-8859-1"?>
    <application>
    <!-- Path to the application -->
    <chemin>C:\FreeDrive\FreeDrive.exe</chemin>
    <!-- Command line -->
    <ligne_commande></ligne_commande>
    <!-- Preview image -->
    <apercu></apercu>
    <!-- Window finding text -->
    <texte_recherche>free drive 0.85</texte_recherche>
    <!-- Description -->
    <description>gps freedrive</description>
    <!-- Run embedded "in-skin" -->
    <run_embedded>0</run_embedded>
    <!-- Show application always on top of other -->
    <ontop>0</ontop>
    <!-- Remove borders of the app. Just set offset for Top,Right,Bottom,Left -->
    <borders_remove>30,5,5,5</borders_remove>
    <!-- Allow multiples instances for application -->
    <allow_multiple_instances>1</allow_multiple_instances>
    </application>
    Make it a xml file and open through applications
    No one got it working through the GPS button by the way?
    Jan 2005
    Got it... When I push the GPS button freedrive starts!! NICE
    Aug 2004
    just a quick note i would change
    to:
    <texte_recherche>free drive</texte_recherche>
    just so when u update the exe file and the version number changes from 0.85 you won't have to edit the xml file
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
    Jan 2005
    Quote Originally Posted by NiN^_^NiN
    to:
    it is the window finding text and I tried it with another app
    (soundcontrol) and the xml file still says free drive 0.85 but it is working!
    So it's ok like this.
    It's nicer to do it your way.
    cheers
    Aug 2004
    it is working cause your loading that app i think it actually locks the app quicker to NMC if the window text is the same as the app.
    Not to sure about that netsuo will have to tell us.
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
    Jun 2004
    Bay Area, California
    how do you link it to the GPS button?
    Aug 2004
    open up the light skin in NMC skin editor then click on all the GPS icons on each seperate page (main, audio, video etc pages)
    double click on the gps buttons on each seperate page and a properties page opens up
    select EXTERNAL_APPLICATION_LOAD under the short press action
    Then next to it you can select the XML file that launches the gps program
    Hope this helps you
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
    Jun 2004
    it did. works like a champ, thanks!
  1. PPC Car GPS and MP3 mini How To
    By hotrod_nut in forum General Hardware Discussion
    Last Post: 02-25-2008, 01:24 PM
  2. Proper Installation of GPS Receiver
    By ummagawd in forum GPS
    Last Post: 04-22-2005, 11:07 AM
  3. Replies: 9
    Last Post: 10-25-2004, 01:34 AM
  4. Window Tint's effect on GPS signal
    By MoFo in forum GPS
    Last Post: 07-19-2004, 05:08 PM
  5. Music and GPS
    By Mikesz in forum GPS
    Last Post: 02-28-2003, 02:26 AM
