I assure you I am not mixing things up.Originally Posted by RoyN
but is this an option you recall for neocar?
there is a option in NMC to remove single tap but its not useful for what you want.
Netsuo might be able to add a button which cycles through the sub dirs and creates a playlist to play if you wanted to but i never have a problem swapping albums it does take a while but you dont have to take your eyes off the road.
Im sure you can hit a button and it can skip to the next directory i'll have a look when im at home and see what i can find.
Also NMC is setup for 2 different functions for each button
You can set the GPS button to load up Freedrive when pressed but you can also set it up so if you hold the GPS button down it loads up map monkey and that is handy for people who use Freedrive but also use something else like streets and trip![]()
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
this is an option in NMC if you look through the NeoCar Manager you will see an option for turning single tap off.
I also think if that doesn't work it might be a setting on the touchscreen as i have had that problem ages ago but it wasn't setup properly i think.
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
I had a look and thought there was an option to go to the last file in a dir
I was gonna set it to last file in the list then next so at a push of a button u change dir's but i can't do it.
It would be easy for netsuo to add a option to go to the last file in a dir so maybe ask for that feature![]()
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
