Page 15 of 16 FirstFirst ... 5678910111213141516 LastLast
Results 141 to 150 of 153
Thread: wants, needs, suggestions, comments and more
  1. #141
    Variable Bitrate super-fly's Avatar
    Feb 2006
    NJ
    I have downloaded the latest version from the site and am not exactly sure how to have something external luanch, like safari or VMware. Also, what exactly was bugbytes solution, all I saw was his suggestion.
  2. #142
    Variable Bitrate NeonDev's Avatar
    Feb 2008
    I'd have to search for bugbytes exact method (or ask him) but IIRC it is just assigning NBB and VMware to separate spaces and using a controller to trigger the switch between the 2 spaces.
    If you download the example from the SDK thread you can find a compiled module it the project that opens safari in an "embedded" window ontop of NBB. just do a "show package contents" on that module and find the launch apple script and edit it to load VM ware/iguidance instead. you will probably want to change the window dimensions in the script as well. that is all assuming something drastic hasn't changed in NBB that would break that module. If so then the example would likely have to be recompiled.
    check us out at: www.neonboombox.com
  3. #143
    Constant Bitrate golfguy's Avatar
    Nov 2006
    Fort Worth, TX
    I run NBB in one Space and VMWare/Windows XP running Garmin Mobile PC in another Space. Then I use a Griffin PowerMate to switch between Spaces to flip between NBB and Nav. It would be nice to have a touch-screen trigger, but the PowerMate works very well, too.
    Any day is a good day for golf.
    Mazdaspeed6 Carputer Progress: Gone
    (Check Speedy's Install)
    Speedy was traded for a 2004 350z - Install complete except for permanent screen installation.
  4. #144
    Feb 2008
    you can use the launchscript in the example module to have applescript send the spaces key combo to the "system events" app thus triggering spaces. of curse that leaves you kinda stranded as far as getting back.
  5. #145
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by NeonDev View Post
    That's it. Just assign the VMware to launch in a separate space. Also, reduce the number of spaces to just 2 and you can flip flop them with a single key.
    Want to:
  6. #146
    Feb 2006
    NJ
    I came up with a way to switch betwenn NBB and gps and anything else for that matter that works pretty good. I downloaded a program called dock-it, which lets you create custom docks. So I just made a dock with spaces on it and made the dock background completely transparent so now I just have a small spaces icon floating there in the upper left had corner that floats on top of everything. I just have NBB bound to one space, iGuidance bound to another, DVD player to another, and misc. other stuff bound to the other. So I just hit the spaces icon and choose the space.
    Here is what it looks like on the now playing screen, the icon looks a little out of play but its not horrible, it loos a little more out of place on the home screen (you can kind of imagine where it would be on that screen. On the iGuidace screen it looks like it belongs there though. Also, when you have a dvd playing in full screen the icon is hiddien so it works out well.
  7. #147
    Feb 2008
    just found a link to this in another thread. thought it might work well for some people to switch between nbb and other programs.
    It is a mouse gestures program, and im thinking you can program a gesture to trigger spaces back and forth
  8. #148
    Feb 2006
    NJ
    Yeah I tried that. It didnt work that great.
  9. #149
    Feb 2008
    Quote Originally Posted by super-fly View Post
    that's unfortunate. have you tried this similar software called cocoasuite?
  10. #150
    Feb 2006
    NJ
    yeah but that only works with cocoa apps i believe...its not global
  1. More info on OPUS automotive ATX power supply
    By InvisiBill in forum Power Supplies
    Last Post: 08-16-2002, 02:19 PM
