Page 4 of 16 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 153
Thread: wants, needs, suggestions, comments and more
  1. #31
    Variable Bitrate NeonDev's Avatar
    Feb 2008
    well yeah it is coming. Don't know about it being in 5 tho. I have kinda put key bindings in front of sticky preferences in the priority queue... of course if the actual users of NBB can easily sway me if they complain enough ;-)
    check us out at: www.neonboombox.com
  2. #32
    Feb 2008
    Leeds (UK)
    Now that I'm running NBB constantly on my mac mini (it goes to sleep when I turn the engine off and resumes NBB on wake), I've noticed that the "hide cursor" option resets whenever the screen saver kicks in, or the mac resumes from sleep.
    Only a small point, and you may already have it pencilled in for future releases, but just incase you dont....
  3. #33
    Feb 2008
    actually i was unaware of that... dosn't sound too hard to fix so it'll prolly be fixed in the next release. does this happen when you sleep the computer from NBB too? I assume it has something to do with the application loosing its key status
  4. #34
    Feb 2008
    that is fixed now. it will trouble you no more once release 5 is out
  5. #35
    Mar 2008
    Hi everyone,
    very cool FE the NeonBoomBox, I like the look and feel!
    My problem: I don't get any media into it
    I am running 10.5.2 on a Mac Mini Intel. Is there maybe an extra control panel for NeonBoomBox where you define your media Library's (iTunes, iPhoto etc.)? I looked in Application Support and even in the application packages itself. The only Settings I could adjust are the color schemes under the settings wheel in NeonBoomBox, but every time I restart NeonBoomBox, even these settings are back to beginning.
    I am using the newest Build: s0m34rb1tr4ry# from the NeonBoomBox website. What am I doing wrong?
    Best regards,
    California_2006
  6. #36
    Feb 2008
    Leeds (UK)
    You need to have an itunes library set up, then NBB will automatically use it
  7. #37
    Feb 2008
    w6csmith is correct simply use an itunes library. FYI release 5 will be out shortly (waiting for updated graphics and trying to fix a problem with the center of the dial wheel having a wobble) with many improvements (there may be some slight speed hits due to some debugging code I left in)
    release 6 will have improved speed. namely in the color changing department and release 6 will also remember user settings among other things.
    if there is anything else you guys want in the next release youd better make them known
  8. #38
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Let it stretch to fill the screen for those of us with 8.4" screens :-)
    Want to:
  9. #39
    Feb 2008
    i think i can manage that. can somebody provide a small list of common resolutions for car pcs? obviously I am only aware of 800x480 but would happily support others if only they are brought to my attention
    I suppose I could simply resize according to the system resolution, but I am a bit reluctant because I don't want the interface to get squished or anything. I will look into that but I would still appreciate a list at the very least to provide in the settings window...
  10. #40
    Mar 2008
    Thanks for the answer!
    Maybe the problem is, that my iTunes Library is on a different partition? Would be a good idea to have a configuration panel in NBB to choose the library's for iTunes and iPhoto.
  1. More info on OPUS automotive ATX power supply
    By InvisiBill in forum Power Supplies
    Last Post: 08-16-2002, 03:19 PM
