Originally Posted by
NeonDev
you don't. read the change log to see what is changed. 8B is over a week old but for some reason was never posted until yesterday. our bad.
the keyboard is in release 9 as well as a fix for that filter issue among others. it should be released tomorrow night if all goes well
I assume when you say you can't get to the other filters you have "tabbed" to the first one and then hit "up" or "down" to try and go to the next/previous one but it doesn't correct? by that i mean "tab" will cycle through the table the filter 'tray' the options button and the home button. press up/down when anything that is not 'scrollable' is focused and focus will also jump to the filter tray. there is a decent guide on key bindings in the guide thread if you haven't read it.
F.Y.I - I know you use a rotary controller, but I don't know if you have a touch screen. the keyboard in release 9 doesn't support a rotary controller mostly because right now the keyboard can only be used for quick search. nothing fancy. scrolling with a rotary controller is prolly just as quick
