looks like some people got close before they fell mysteriously silent.
http://www.mackb.com/Uwe/Forum.aspx/...ay-drm-ed-file
I wouldn't count on it happening without apple being the provider of the API which doesn't seem likely. DRM ****es me off so much. look at it only punish those of you who pay; its not fair. I guarantee you no pirates using NBB are having trouble watching their videos!
well the itunes.xml has a "protected" field that i can use to filter out videos that are protected. release 9 will no longer show protected videos at all.
well the application didn't crash but, in the music module where you select the artists NBB has created about 12 of the same artist (Nas) and is displaying the exact same content under each one. I checked itunes and nothing seems wrong so i checked front row and everything is under 1(Nas). So im not to sure. what do you think?
O never mind i fixed it some how
yeah NBB doesn't "create" any thing in its library. it reads the iTunes library file. Usually when artists and the like appear duplicated it is because of a space at the end of one of the song tags or a capitalization issue as NBB is case sensitive at the moment but iTunes is not.
In both release 9 versions I have had problems with the audio control row. In 9a the pause/play control did not appear in the row, but still worked when touched. In 9b the pause/play now appears but the forward control does not, and likewise still works when touched. Have you had any other reports of similar behavior?
no I haven't. that is a bit interesting. I would say it may have something to do with the button effects I was trying to integrate but that would only affect 9B and on.
I plan on releasing 9C late tonight/early tomorrow maybe that will mysteriously help.
what resolution are you on? also, open the console and see if there are messages about missing graphics.
I have a Lilliput EBY701 at 800x480. I checked the console and the only NBB items were unhide and hide mouse events.
i know there are more messages than that posted...
i'm completely stumped. I even dropped my res down to 500x600 (the closest i can to 480x800). everything works perfectly for me. can you test it on another system or on a higher res? 800x600 maybe...
on another note I completely screwed up the guts of NBB tonight while working on some cool new things and it will take me another day or two in order to get a release out
No matter what resolution i run the program at, it opens up and then unexpectedly quits. I can get you a crash log if i knew where they were.
crash log should be at ~/library/logs/crash reporter
console output is even more valuable then crash logs. just open up the console application and copy and paste the output from NBB here and I can probably figure it out.
I going to have to ask if you are running leopard since if you are not you will get the same result.
Boombox.app/Contents/MacOS/Neon\ Boombox ; exit;
2008-06-04 16:46:00.911 Neon Boombox[15944:10b] initializing dial...
2008-06-04 16:46:00.938 Neon Boombox[15944:10b] observing modules...
2008-06-04 16:46:00.967 Neon Boombox[15944:10b] keyboard create:x:0.000000, y:182.857147, w:2560.000000, h:765.291016
2008-06-04 16:46:00.972 Neon Boombox[15944:10b] ModuleController initialized...
2008-06-04 16:46:01.238 Neon Boombox[15944:10b] custom slider awake
2008-06-04 16:46:01.486 Neon Boombox[15944:10b] unhide mouse
2008-06-04 16:46:01.487 Neon Boombox[15944:671b] loading (9) module(s)...
2008-06-04 16:46:01.567 Neon Boombox[15944:671b] keyboard:<PXVirtualKeyboard: 0x245220>
2008-06-04 16:46:01.583 Neon Boombox[15944:10b] appdelegate attempting to insert to dial...
2008-06-04 16:46:01.584 Neon Boombox[15944:10b] remaining button count:10 module:<PXGamesModuleController: 0x21c530>
2008-06-04 16:46:01.584 Neon Boombox[15944:10b] no dial positions set
2008-06-04 16:46:01.585 Neon Boombox[15944:10b] module:PXGamesModuleController index:0
2008-06-04 16:46:01.586 Neon Boombox[15944:10b] button added
2008-06-04 16:46:01.669 Neon Boombox[15944:671b] keyboard:<PXVirtualKeyboard: 0x245220>
2008-06-04 16:46:01.679 Neon Boombox[15944:10b] appdelegate attempting to insert to dial...
2008-06-04 16:46:01.680 Neon Boombox[15944:10b] remaining button count:9 module:<PXGPSModuleController: 0x16a23a60>
2008-06-04 16:46:01.680 Neon Boombox[15944:10b] no dial positions set
2008-06-04 16:46:01.681 Neon Boombox[15944:10b] module:PXGPSModuleController index:1
2008-06-04 16:46:01.682 Neon Boombox[15944:10b] button added
2008-06-04 16:46:01.756 Neon Boombox[15944:671b] keyboard:<PXVirtualKeyboard: 0x245220>
2008-06-04 16:46:01.791 Neon Boombox[15944:10b] appdelegate attempting to insert to dial...
2008-06-04 16:46:01.792 Neon Boombox[15944:10b] remaining button count:8 module:<PXInternetModuleController: 0x16a22670>
2008-06-04 16:46:01.792 Neon Boombox[15944:10b] no dial positions set
2008-06-04 16:46:01.792 Neon Boombox[15944:10b] module:PXInternetModuleController index:2
2008-06-04 16:46:01.794 Neon Boombox[15944:10b] button added
2008-06-04 16:46:01.803 Neon Boombox[15944:671b] initializing movie controller
2008-06-04 16:46:01.803 Neon Boombox[15944:671b] opening iTunes XML
2008-06-04 16:46:02.034 Neon Boombox[15944:671b] using location:~/Music/iTunes/iTunes Music Library.xml
2008-06-04 16:46:02.034 Neon Boombox[15944:671b] iTunes XML opened
2008-06-04 16:46:02.036 Neon Boombox[15944:671b] dividing library tracks
2008-06-04 16:46:02.041 Neon Boombox[15944:671b] checking for ready modules... 0 ready but not enabled
2008-06-04 16:46:02.042 Neon Boombox[15944:671b] module ready notification posted
2008-06-04 16:46:02.223 Neon Boombox[15944:671b] Unknown Window class PXVisualizerWindow in Interface Builder file,
creating generic Window instead
2008-06-04 16:46:02.477 Neon Boombox[15944:671b] custom slider awake
2008-06-04 16:46:02.544 Neon Boombox[15944:671b] awaking movie controller
2008-06-04 16:46:02.544 Neon Boombox[15944:671b] actions set
2008-06-04 16:46:02.546 Neon Boombox[15944:671b] movie module awoken
2008-06-04 16:46:02.549 Neon Boombox[15944:671b] keyboard:<PXVirtualKeyboard: 0x245220>
2008-06-04 16:46:02.804 Neon Boombox[15944:10b] appdelegate attempting to insert to dial...
2008-06-04 16:46:02.804 Neon Boombox[15944:10b] remaining button count:7 module:<PXMediaViewerController: 0x16a0f9c0>
2008-06-04 16:46:02.805 Neon Boombox[15944:10b] no dial positions set
2008-06-04 16:46:02.805 Neon Boombox[15944:10b] module:PXMediaViewerController index:3
2008-06-04 16:46:02.807 Neon Boombox[15944:10b] button added
2008-06-04 16:46:02.823 Neon Boombox[15944:671b] initializing music controller
2008-06-04 16:46:02.824 Neon Boombox[15944:671b] opening iTunes XML
2008-06-04 16:46:03.054 Neon Boombox[15944:671b] using location:~/Music/iTunes/iTunes Music Library.xml
2008-06-04 16:46:03.055 Neon Boombox[15944:671b] iTunes XML opened
2008-06-04 16:46:03.107 Neon Boombox[15944:671b] toggle shuffle
2008-06-04 16:46:03.108 Neon Boombox[15944:671b] /Users/bobby/Desktop/Neon Boombox.app/Contents/Resources/Modules/PXMusicModule.module/Visualizers/
2008-06-04 16:46:03.184 Neon Boombox[15944:671b] custom slider awake
2008-06-04 16:46:03.553 Neon Boombox[15944:671b] custom slider awake
2008-06-04 16:46:03.728 Neon Boombox[15944:671b] awaking music controller
2008-06-04 16:46:03.729 Neon Boombox[15944:671b] selection changed
2008-06-04 16:46:03.729 Neon Boombox[15944:671b] browser level set
2008-06-04 16:46:03.730 Neon Boombox[15944:671b] music module awoken
2008-06-04 16:46:03.738 Neon Boombox[15944:671b] keyboard:<PXVirtualKeyboard: 0x245220>
2008-06-04 16:46:04.288 Neon Boombox[15944:10b] appdelegate attempting to insert to dial...
2008-06-04 16:46:04.288 Neon Boombox[15944:10b] remaining button count:6 module:<PXMusicController: 0x1bdf7700>
2008-06-04 16:46:04.289 Neon Boombox[15944:10b] no dial positions set
2008-06-04 16:46:04.289 Neon Boombox[15944:10b] module:PXMusicController index:4
2008-06-04 16:46:04.291 Neon Boombox[15944:10b] button added
2008-06-04 16:46:04.297 Neon Boombox[15944:c81b] checking for ready modules... 1 ready but not enabled
2008-06-04 16:46:04.299 Neon Boombox[15944:c81b] enabled a waiting module... 0 still waiting
2008-06-04 16:46:04.312 Neon Boombox[15944:c81b] module activaited without wait
2008-06-04 16:46:04.312 Neon Boombox[15944:c81b] module ready notification posted
2008-06-04 16:46:04.425 Neon Boombox[15944:671b] keyboard:<PXVirtualKeyboard: 0x245220>
2008-06-04 16:46:04.499 Neon Boombox[15944:10b] appdelegate attempting to insert to dial...
2008-06-04 16:46:04.500 Neon Boombox[15944:10b] remaining button count:5 module:<PXPhoneModuleController: 0x1b262850>
2008-06-04 16:46:04.500 Neon Boombox[15944:10b] no dial positions set
2008-06-04 16:46:04.501 Neon Boombox[15944:10b] module:PXPhoneModuleController index:5
2008-06-04 16:46:04.503 Neon Boombox[15944:10b] button added
2008-06-04 16:46:04.640 Neon Boombox[15944:671b] keyboard:<PXVirtualKeyboard: 0x245220>
2008-06-04 16:46:04.647 Neon Boombox[15944:10b] appdelegate attempting to insert to dial...
2008-06-04 16:46:04.648 Neon Boombox[15944:10b] remaining button count:4 module:<PXPhotoModuleController: 0x16a37240>
2008-06-04 16:46:04.648 Neon Boombox[15944:10b] no dial positions set
2008-06-04 16:46:04.649 Neon Boombox[15944:10b] module:PXPhotoModuleController index:6
2008-06-04 16:46:04.650 Neon Boombox[15944:10b] button added
2008-06-04 16:46:04.663 Neon Boombox[15944:671b] channel table:0 rows
2008-06-04 16:46:04.876 Neon Boombox[15944:671b] An uncaught exception was raised
2008-06-04 16:46:04.877 Neon Boombox[15944:671b] *** -[NSCFArray objectAtIndex:]: index (0) beyond bounds (0)
2008-06-04 16:46:04.878 Neon Boombox[15944:671b] *** Terminating app due to uncaught exception 'NSRangeException', reason: '*** -[NSCFArray objectAtIndex:]: index (0) beyond bounds (0)'
2008-06-04 16:46:04.878 Neon Boombox[15944:671b] Stack: (
2494812747,
2490994939,
2494812203,
2494812266,
2519307231,
2518774296,
509310106,
11650,
2518795693,
2518794580,
2502659157,
2502658834
Trace/BPT trap
logout
[Process completed]
Yes I am running leopard. I have all updates as well. 10.5.2
